Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-12-2014 | 05:26 AM
  #13126
R/C Tech Elite Member
Originally Posted by Madjake
What's the difference between the lrc brace ad the lrc inserts. I have the inserts do I need both
I believe both lower your roll center by the same amount but the brace allows you to change your rear toe while the pills do not.
iScream is offline
Old 08-12-2014 | 05:58 AM
  #13127
cpt_RedBeard's Avatar
Originally Posted by Cain
anyone else here try 6 hole x 1.5mm pistons ?
tried these on my SCT410 this past weekend and it was the best the vehicle has ever felt. want to give the EB48 a try with these, assuming same principles apply.
I did some extensive testing with the 6x1.5s last week. The key to them is to increase the shaft speed. You can achieve this by adding a progressive stroke to the shock by laying the shocks over. To get the full benefit of the package, I suggest using the outer upper hole on the arm and hole 2 or in on the tower.
Personally I liked the LRC brace better based on feel alone. As for numbers iscream was correct using the brace maintains the ability to adjust your toe while running the pins in a LRC position. Also the LRC brace is only +1 degree of toe over stock .1 spec. Where the stock .2 brace is +1.5.
cpt_RedBeard is offline
Old 08-12-2014 | 07:14 AM
  #13128
Cain's Avatar
Tech Legend
Thanks. the suspension action definitely was improved and I didn't have the worry of the nose down condition except on one spot that I think a stiffer spring my remedy. (was using Tekno greens, going yellows).
What spring package do you recommend with the 6 x 1.5s for the eb48?
Thinking of going in 3rd position from outer on the tower front and rear too.
Oh, one other question, when you run the V1 style A-arms, how much of a mm difference do you need to account for on droop when you use the outer hole versus the new style a-arm outer holes?
measuring I thought it was about 3mm difference or so.
Cain is offline
Old 08-12-2014 | 08:42 AM
  #13129
We were running pink up front and red in the rear still.
The positions sound good all around.
As for the droop, I measured the droop using the middle hole in the arm instead of using the bolt for consistency.
Old 08-12-2014 | 08:48 AM
  #13130
Cain's Avatar
Tech Legend
Good idea on the droop measurement!
In general what do you recommend as a rear droop setting to start with? I am doing 122mm with the V1 rears but measured at the bolt and outer a-arm position. basically what I thought was 119mm with new a-arms rear spot. But your idea makes better seense.
Cain is offline
Old 08-12-2014 | 09:06 AM
  #13131
8ight-e's Avatar
Has anyone figured out how to keep the inner hinge pins from getting build up on them and by build up I mean crusted to the point the arms stop moving properly if you let it go too long? I have to clean these every couple races and by clean I mean break out the dremel tool and polish them to get the hardened crud off :P
I guess if you don't run on a treated track or where they water much you may not see the same build up but I'm guessing it's something in how the a-arms are manufactured as I've been racing on this track for years and never had this happen w/ any other make. Not complaining, as I'm more consistent and faster w/ eb48.2 than any other model.. just looking for some feedback on this.. I was debating small washers on each end or some grease or something to help keep some out of the space. BTW if your buggy is acting up a little I suggest checking them out. You don't need to take off the diff's to pull off the alum holder and pull the pins (which I do appreciate cleaning these so much lol)
8ight-e is offline
Old 08-12-2014 | 09:16 AM
  #13132
I found a Teflon dry lube or a light smear of grease helpes, but fine clay dust always works its way in there. I usually clean that area more than any other on the car.
Old 08-12-2014 | 10:36 AM
  #13133
Is there any other shock boots that fit and last longer? the stock one's are kinda carp.
ebay007 is offline
Old 08-12-2014 | 10:51 AM
  #13134
Advantage Racing Products has a nice hinge pin lube that works very well and cuts down on the amount of time you would have to clean the pins and re-lube them! Check it out:
http://www.advantageracingproducts.c...?idproduct=223
ehartman_49348 is offline
Old 08-12-2014 | 10:57 AM
  #13135
Any body try the csi red pistons?
Rickybob is offline
Old 08-12-2014 | 11:06 AM
  #13136
rcboy1's Avatar
If you cut about 5mm off the end of each boot and simply let it rest above the spring perch they will last far longer. More dirt will get inside, but it will prevent tearing.
rcboy1 is offline
Old 08-12-2014 | 11:14 AM
  #13137
are you cleaning the inside of the arm out when you are polishing the inner hinge pins? If you aren't pick up some disposable masquera brushes and clean the arms as well if you don't have a arm reamer.
micrors4guy is offline
Old 08-12-2014 | 11:42 AM
  #13138
Numburn's Avatar
I just ordered a 4mm Integy arm reamer off eBay yesterday. Got tired of borrowing.
Numburn is offline
Old 08-12-2014 | 11:49 AM
  #13139
Nemaris's Avatar
Yeah, I think some of it may be guys once they got the 10 minute designation kind of sourced their lipos to the length.
Back in the day there wasn't tons of options that didn't act like a big pig hanging on the vehicle. Usually have find a sweet spot with battery weight which to me seems to be in the 5000mah-ish range that I am liking but in the past before stuff really got going for RC I have used the 6000mah packs from PolyRC.
So would you guys say that 5000mah such as the two SMC offer have been the sweet spot for weight? I just built my eb48, and have been more used to the eb48SL geometry and weight.
Nemaris is offline
Old 08-12-2014 | 11:52 AM
  #13140
Numburn's Avatar
I think 500g give or take is the sweet spot. 570g seems a bit heavy.
Numburn is offline
