Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-13-2014 | 05:57 AM
  #7276
Maximo's Avatar
Originally Posted by cczjordan
I got confuse with this 3 pipe:
1. 9886 top end with good botom?
2. 9901 overall with fuel economy
3. 2096 top end with tame bottom?
Guess manifold 41021will be general use
ON a stock Paloma/Bonito the 9886.41001 has the most bottom of any of the pipe combos...more midrange and more top end..... everywhere under the curve is stronger with a 9886...the 99012/41021 will neuter the Poloma badly...Some of the pipe recommendations given are bad for this engine.... Long manifolds and 9901 ? maybe if your looking to severely detune the engine ......just like the old recommended 2084 combo, horrible !
9886/41001...on these engines nothing else comes close...
BTT is the same way.9886/41001 out powers everything else, even right off the bottom end...
Maximo is offline
Old 11-13-2014 | 06:41 AM
  #7277
am
9886 is no longer valid for ERFA/Ifmar events.
am is offline
Old 11-13-2014 | 07:01 AM
  #7278
Maximo's Avatar
[QUOTE=am;13655407]9886 is no longer valid for ERFA/Ifmar events.[/QUt
that sucks...as it is quite a well rounded pipe on many of the Nova's...Short pipe with high fuel pressure.Gives great low end throttle response with a good top end run out. Slippery tracks its maybe too much, but if there is traction it works extremely well on the Nova's...Just in the fall time we ran a stock Keep-off 7 port on the 9886/41001 combo and it was extremely impressive on the bottom end, gobs of grunt even with a low clutch stall.With that pipe the engine feels how a ultra long stroke should feel with piles of low RPM power. On our sticky clay track surface it gives the engine tractor like low end where most other pipes seem to sap the bottom end..As counter intuitive as it sounds that pipe and header combo amplify the bottom end much more then the top end on those ultra long stroke Nova's, and visa versa with the long manifold pipe header combo's, the longer the manifold the milder the engine behaves down low
Maximo is offline
Old 11-13-2014 | 07:15 AM
  #7279
cczjordan's Avatar
In terms of fuel consumption?
cczjordan is offline
Old 11-16-2014 | 03:54 PM
  #7280
Got the buggy sorted out. What Nova setup for a truggy? Looking for good mileage and some good bottom end
Er8sr is offline
Old 11-17-2014 | 04:28 PM
  #7281
Losi RE12 pipe? Good? Milelage? Power?
9901 knock off? thats what i heard...not sure if true....
brmena101 is offline
Old 11-17-2014 | 06:32 PM
  #7282
KyoshoRed's Avatar
Ok out of all the Nova pipe/manifold combos which one gets the best mileage forget power smoothness all that just best gas mileage?
KyoshoRed is offline
Old 11-17-2014 | 11:10 PM
  #7283
Lille-bror's Avatar
Edit / Hpi / Crono Efra 2032
Lille-bror is offline
Old 11-18-2014 | 04:22 AM
  #7284
beidle99's Avatar
Is the Jp 2032 the same as the edit 2032? I know that it should be but the front of the JP pipe looks different then the edit pipe. What header to run with the the 2032?
beidle99 is offline
Old 11-18-2014 | 10:53 AM
  #7285
Lille-bror's Avatar
Yeah they looks similar to my Edit. They are no longer approved and are very fragile unless you get the Crono SS version.
I use Novarossi 41001 header.
Old 11-18-2014 | 11:06 AM
  #7286
KyoshoRed's Avatar
how about a pipe that is still available? lol
Old 11-18-2014 | 02:21 PM
  #7287
Grinder's Avatar
41021/2096
41021/9901
These seem to be the best for mileage. The 2096 has a slight advantage in mileage over the 9901.
Grinder is offline
Old 11-18-2014 | 03:25 PM
  #7288
Originally Posted by Grinder
41021/2096
41021/9901
Trust me, he knows what he is talking about. If you look at the last page or two of the Murnan motors thread there is a pick of how much fuel is left in my tank after a main. That was with a modded P5 and the 41021/2096 combo.
mwiley is offline
Old 11-18-2014 | 06:15 PM
  #7289
Autocratic's Avatar
Anyone have experience with the Beat B4?
Autocratic is offline
Old 11-18-2014 | 06:27 PM
  #7290
KyoshoRed's Avatar
41021/2096
41021/9901
TY for the straight answer
