NOVAROSSI Engine thread....
#7426
This should help. Look at the bottom. I havn't played with plugs but maybe I should.
http://www.novarossi.it/2012/index.p...-p5-tuned.html
#7427
I've just recently come back to nitro and I have a question about glow plugs. I broke in my P5 with the plug that came with it, then I ran it for 1 practice day with the supplied plug. After talking with the lhs guys, they recommended that I switch to the plug one step colder because of our current cold temperatures which are between 40 and 60 degrees. I've changed to a Novarossi #5 plug. My 1st question is, what direction will the tune of my motor go? ie, will I be leaning or richening it? My 2nd question is, at what ambient temperature should I go to the #6 plug?
The temp range for the #6 as per the Nova chart is roughly 50-80F. As for the tune, again there are other variables so my rule of thumb if you change plug temp is run it with existing needle settings...then tune from the engines look, feel, sound, etc. But to answer your direct question, if anything you may have to richen when going to the hotter plug.
Hope this helps...best of luck with your new P5.
#7430
a C6tgc works fine in the temps you said although above 90 I would try a c7tgc just to keep it from burning up unless its humid outside then stay with the c6tgc.
#7431
But when I asked Adam the same question, he said that he doesn't change the plug for temps. He told me that humidity plays more of a factor than temp does. I'm still kinda confused about the whole subject, but as evidence of what Adam said being right (as if he needs evidence when it comes to tuning engines), when it was 95-100 degrees at AMS 5.0 in Alabama last year, I'm pretty sure that Adam, and most guys too, still ran the C6 plug. Many of us had tuning problems, and suffered multiple flame outs, but when I asked Adam afterwards, he said that you needed to tune the motor inside of the building, where the humidity was probably 100%, instead of outside, where it was 20-30% less humid.
Things are as clear as mud to me now!
#7434
I called Novarossi last year and spoke with someone at length about this very thing. The gist of the conversation was that higher temps require a colder plug, and the referred me to their temperature chart. http://www.novarossi.it/2012/index.p...-off-road.html
We tend to run all year round all over Australia using the C6TGC without any problems, Temps ranging from 45F - 105F, I know this is well outside the Novarossi chart range but we don't suffer any problems
There no doubt should be benefits to running a cooler plug when its hot (specially if humidity is low) so i might experiment with using the C7TGC on the hot days (say above 32/35c - 90-95f) and see what we find
Dave'
FUSION X ENGINES AUSTRALIA
#7435
#7436
Dave'
Dave'
#7438
#7440
A lot of people use the 97T, but I wasn't a big fan. I did have a bunch of these fail on me.
But on my race engines, I still run a Nova plug. They seem to be the most reliable.
352Likes
