The AE FActory Team B44.2 Thread >
Old 10-16-2014 | 02:19 PM
  #8161
How are you guys putting a oneway in the front of a B44.2?......what parts are needed??
Mallard is offline
Old 10-16-2014 | 04:59 PM
  #8162
TOO-TALL's Avatar
Got my shorty chassie today.and the screw hole on the bottom are not countersunk.....this can't be right? Anyone that has done the conversion had this problem?
TOO-TALL is offline
Old 10-16-2014 | 10:29 PM
  #8163
Nemaris's Avatar
Yeah that isn't right, Schelle chassis right? I would contact Schelle/Associated and have them send you out a new one. Also a lot of imperial sized screws you can get off the internet and at ace etc don't sit in the counter sunk holes all the way. Make sure to use associated screws, or get Lunsford titanium flat head screws for the bottom of the chassis so they seat all the way down.
(Of course if you have a 4-40 countersink bit you could do it yourself easily since the holes are already there
Nemaris is offline
Old 10-16-2014 | 11:08 PM
  #8164
kdub's Avatar
Email us [email protected], please take pics if you can, thanks! We will get you fixed up.
kdub is offline
Old 10-16-2014 | 11:22 PM
  #8165
TOO-TALL's Avatar
I Left a message at Schelle this afternoon
TOO-TALL is offline
Old 10-17-2014 | 08:09 AM
  #8166
WonTonsChicken's Avatar
Ive been looking all over, and havent found an answer to wether or not you can use the 44.3 diffs in earlier versions.. Any help would be appreciated.
WonTonsChicken is offline
Old 10-17-2014 | 08:56 AM
  #8167
You just need to use the new input shafts and pinion gears along with the diffs.
Krio is offline
Old 10-17-2014 | 09:33 AM
  #8168
Thanks!
Old 10-17-2014 | 10:11 AM
  #8169
TOO-TALL's Avatar
Email sent
TOO-TALL is offline
Old 10-25-2014 | 05:01 PM
  #8170
Drift_Buggy's Avatar
Does anyone here seal the chassis with glue? If so, how did you do it?
Was watching a video on youtube of it, considering doing it that way.
https://www.youtube.com/watch?v=mMMt162bcTo
Drift_Buggy is offline
  #8171
Old 10-25-2014 | 08:46 PM
  #8172
Hey guys, I did a search but couldn't find any discussions on the specific parts you'll need to fit the B44.3 center gear diff in the B44.2? I plan on running ball diffs on the front and rear. So I figure I won't need to the new B44.3 outdrives.
Anyone? I currently run the Avid chasis. I'm assuming that the following would be needed:
#9946 B44.3 chasis
#9944 B44.3 floating servo brace
#9943 B44.3 floating servo mount
#9932 B44.3 motor mount
#9950 B44.3 front top plate
#9951 B44.3 rear top plate
The center gear diff kit
#9938 B44.3 spur gear
#9953 B44.3 battery strap
#9952 B44.3 battery tray
Sound about right? Thanks.
loosenut is offline
Old 10-25-2014 | 08:55 PM
  #8173
Man...I quickly did the math. It'll cost about upwards of $250 + to upgrade my b44.2 to b44.3 center gear diff only (running ball diffs front and rear). I might as well just buy the new b44.3 kit!
loosenut is offline
Old 10-30-2014 | 12:59 PM
  #8174
kdub's Avatar
Got this resolved Enjoy your 44.2 Shorty!
kdub is offline
Old 11-02-2014 | 05:19 PM
  #8175
Hey guys I got my RPM a-arms. While installing I notice there is not a second hole for the small screw that retaina the hinge pion on the outer end of the arm. How is the pin kept in the arm?
Bracer11 is offline
