The AE FActory Team B44.2 Thread >
Old 03-31-2014 | 04:00 PM
  #7411
Originally Posted by mschumi101
If you really need the extra durability it could be something to look into. I have never broken anything other than a ballcup on the rear end of my buggy. The arms seem solid to me, so why change?
For the same reason I run rpm front arms and rear hubs, Lunsford turnbuckles, and Losi ball cups and studs. Insurance.
fredswain is offline
Old 04-01-2014 | 04:54 AM
  #7412
TomErickson's Avatar
I am running RPM arms and ball cups for durability. The FT rear hubs are fine IMHO. I have broken two rear arms over the past 6 months but both times I either hit one of the nails that pin the tubing to the track or something similar.
TomErickson is offline
Old 04-01-2014 | 05:01 AM
  #7413
I have been studying another option for a Gear Diff. The Durango gear diffs use a 10x15x4mm bearing. I test fitted a 10x16x4mm bearing and it fit almost perfectly into the diff case. So instead of purchasing a machined bearing sleeve why not just is the proper bearing. I pulled these bearings from my SC10 4x4.
I am also planning to test fit a Caster S10B diff into the case. The ring gear is the same size so if the width fits It would be a good alternative. I have access to a pinion gear that uses a pin instead of the key but it will need to be shimmed to the shaft. I'll post photos if I get this to work. Caster Diff kits are $43 and the SC104x4 bearings are $7.29 a pair. So for about $100 for a set of Gear Diffs.
Old 04-01-2014 | 07:10 AM
  #7414
Originally Posted by TomErickson
I have been studying another option for a Gear Diff. The Durango gear diffs use a 10x15-4mm bearing. I test fit a 10x16x4mm bearing and it fit almost perfectly into the diff case. So instead of purchasing a machined bearing sleeve why not just is the proper bearing. I pulled these bearings from my SC10 4x4.
I am also planning to test it a Caster S10B diff into the case. The ring gear is the same size so if the width fits It would be a good alternative. I have access to a pinion gear that uses a pin instead of the key but it will need to be shimmed to the shaft. I'll post photos if I get this to work. CAster Diff kits are $43 and the SC104x4 bearings are $7.29 a pair. So for about $100 for a set of Gear Diffs.
that would be awesome keep us posted
Rocktoy71 is offline
Old 04-01-2014 | 08:23 AM
  #7415
Pro10noob's Avatar
Regards Roy
Pro10noob is offline
Old 04-01-2014 | 11:31 AM
  #7416
How do u keep the rear locked in on the b44.2 mine is just constantly loose.
-1 chamber. Ride height at 21mm and 27.5 shock oil on b44.1 shocks
xTotalghost is offline
Old 04-01-2014 | 12:46 PM
  #7417
Jmuck69's Avatar
Tires my man...tires.
Jmuck69 is offline
Old 04-01-2014 | 06:42 PM
  #7418
Will the sc10 4x4 prolite gear diffs work in the b44.2?
Old 04-01-2014 | 07:11 PM
  #7419
Fresh barcodes and it is still kinda loose, it is hooked up just not as much as my 2wd
Old 04-01-2014 | 09:02 PM
  #7420
kjohnsiii's Avatar
You could also try the rear ballast weight..
kjohnsiii is offline
Old 04-01-2014 | 09:04 PM
  #7421
I don't think so. The diff bearing is 8x14. The SC10 FT uses a10x16 which fits. If a 8x16 bearing exists that would be the first step. Then you would have to see if the width works.
I did check the Caster diff tonight and it drops in perfect. Now I need to solve the pinion problem.
Old 04-01-2014 | 09:08 PM
  #7422
mschumi101's Avatar
I mean it all depends on track conditions. Barcodes may not give the right side bite for the track, and something else is needed. Also full tread height of a new set may not be ideal either. Sometimes they need to be worn in before they start to work. Not to mention inserts. It can get expensive, but playing with tires can really make the difference and solve your problem. Either that or set up the car to suit the tires.
mschumi101 is offline
Old 04-02-2014 | 04:15 AM
  #7423
StevenOlsen's Avatar
8X16X4 bearing does exists.
StevenOlsen is offline
Old 04-02-2014 | 08:44 AM
  #7424
rcboy1's Avatar
Does the dogbone have enough room for its plunge into the outdrive? When I ran Caster we tried installing their diffs in a 44.2 and ran into an issue we couldnt fix, just cant remember what that was. If they do work itll be awesome since they finally have really good outdrives that hardly wear at all.
Now that I think about it, the issue may have been the dogbone pin is smaller than the casters.
rcboy1 is offline
Old 04-02-2014 | 08:55 AM
  #7425
Originally Posted by rcboy1
Does the dogbone have enough room for its plunge into the outdrive? When I ran Caster we tried installing their diffs in a 44.2 and ran into an issue we couldnt fix, just cant remeber what that was. If they do work itll be awesome since they finally have really good outdrives that hardly wear at all.
I did a fitting of the AE CVA and the pin fit perfect. The overall width of the Caster diff is maybe 0.5mm wider while the bearing the bearing width is narrower so I will need to mic it. The ball on the dog bone was also the right size. The plunge seems the same but I will look at that. So far the only issue I see is that the new out drives are large enough to require some material to be removed from the diff case so that they don't rub or bind.
I will do a full photo layout and dimensional detail on this thread.
