The AE FActory Team B44.2 Thread >
Old 01-09-2014 | 11:20 AM
  #6661
Wildcat1971's Avatar
I also have a tp610dc.
the reedy uses 4mm bullets or you can use an adapter like I links and use deans connectors. The saddles are hooked in series that mean you are going to jumper + and -. That leaves 1 +/- open on each cell. your +/- goes into those respectively. The balancer will use 2 wires. red to pos, black to beg and the middle wire goes to the jumper. Just like that connector I linked you.
here is a video for you.
http://www.youtube.com/watch?v=e3Rr4rOgyVU
Wildcat1971 is offline
Old 01-10-2014 | 05:33 AM
  #6662
SuperRC's Avatar
Hi all, assembling my B44.2 and just put together the slipper. The manual says to have a 2mm gap between the slipper nut and the end of the shaft. But when I barley get the nut started onto the thread, the gap is already approx 6-7mm. Have I assembled something wrong, or is that 2mm in the manual a bit off? I mean just eyeballing it in the manual pics it looks more than 2mm relative to the other slipper components.
Also, I understand that the slipper will be set later when tuning the buggy, but has anyone else found this 2mm measurement in the manual to be off?
SuperRC is offline
Old 01-10-2014 | 07:33 AM
  #6663
That measurement they give you in the manual is the measurement from the b44 style slipper. When they updated the slipper assembly to this new style they did not update it in the manual. Just do as you are doing. Get it started on there are far as you can by hand and then continue with the rest of your build. And like you said, you will set it once the build is complete
skoalisbad4me is offline
Old 01-10-2014 | 07:44 AM
  #6664
godofcable's Avatar
you guys see this? RPM showing the B44 some more love
godofcable is offline
Old 01-10-2014 | 07:51 AM
  #6665
interesting, but I dislike big bumpers. I will just get the new arms
Old 01-10-2014 | 08:12 AM
  #6666
any idea on the weight on it? would it affect any handling characteristics?
Eaglesrx is offline
Old 01-10-2014 | 08:59 AM
  #6667
fq06's Avatar
I think it would improve your front flip rotation count when landing nose down
Most broken arms are from clipping something on the side as opposed to a head on hit... unless you go full clip straight into a wall
fq06 is offline
Old 01-10-2014 | 09:11 AM
  #6668
Wild Cherry's Avatar
Tech Legend
Just noodle arms for beginner's .
Handling will suffer...
Wild Cherry is offline
Old 01-10-2014 | 09:55 AM
  #6669
Waflet's Avatar
Hideeho
Agreed, however, noodle arms for the rear would be an interesting tunning tool.
Waflet is offline
Old 01-10-2014 | 11:07 AM
  #6670
well, I plan to get the noodle arms. The stock ones are way way too fragile
Old 01-10-2014 | 11:30 AM
  #6671
SuperRC's Avatar
Thank you. Yep, that's what I have done.
SuperRC is offline
Old 01-10-2014 | 11:47 AM
  #6672
Everyone complains about the arms, I never have broken one, I mean to break and arm you have to do some real damage
xTotalghost is offline
Old 01-10-2014 | 01:16 PM
  #6673
turbo2cam's Avatar
lol, you should buy lotto tickets cuz you are very lucky my friend! I've looked at the arms cross and they snapped lol. They are for sure the most fragile arms of any RC i've ever owned...
as for the RPM's...noodly or not...at least you finish the race!!! (case and point...worlds)
turbo2cam is offline
Old 01-10-2014 | 02:48 PM
  #6674
Tech Legend
Must be lucky as well, only broken three arms in over a year.
But I know how to drive a 4w...
Old 01-10-2014 | 03:00 PM
  #6675
mblgjr's Avatar
I really don't see why everyone cries over the arms.
They're not bad. I never broke a standard one, nor a hard one. I've been hit, rolled, crashed to the point I thought it was dead for sure... nope. All ok. Heck I even popped the rear shock tower in a wreck and finished the run.
If anything, take the "hard" ones and boil them. I ran them in freezing weather. Didn't break and felt better than the standard ones.
mblgjr is offline
