The AE FActory Team B44.2 Thread
#661
Ok thanks. I should be doing this part of the build today. Just wanted to know if it was a problem. Ill make sure to check the clearance on it while building.
#662
anyone use a Savox servo? if so, what steering horn will fit because i seems like none of them fit's my servo:
http://www.savoxusa.com/Savox_SC1258...avsc1258tg.htm
#663
So i could not wait for the kids to get into bed so i put it in the hudy setup system and stuffed in the batteries, motor and esc and the servo and the camber were way off!! so i made it -1 front and rear as it says in the manual and now there is no clearance problems...
weee thanks for the help guys!
when i got it all put together ill look at it again.
#664
#665
Looky a better starting point than the box stock.
http://www.teamassociated.com/pdf/ca...e_Standard.pdf
#667
I have been using these on my servos, but they're very long and I had to cut the end off of one the other day to get it to work.
The trick is knowing that any horn that fits Futaba servos will work w/ Savox.
#669
#670
#671
When the suspension is fully compressed, the dogbone is hitting the diff nut. Take a little bit off the end, and it stops stressing the diff nut/screw, and allows the suspension to work properly.
#672
I don't see any weight/ballast mentioned in Theilke's setup. Assuming the ballast isn't necessary with the 44.2?
#673
#674
#675
