Like Tree12Likes
Tekno NB48
Old 09-24-2014 | 12:26 PM
  #2416
CaLaBeR's Avatar
Has anyone measured the fuel tank capacity with stock line routing?
CaLaBeR is offline
Old 09-24-2014 | 04:02 PM
  #2417
madweazl's Avatar
Originally Posted by Graham11
I think VP Pro may be selling them
Damn you twice! They did have it in stock but didnt advertise the orange one. I shot them an email and they responded right away to just put my color choice in the special instructions. Twas only money I guess
madweazl is offline
Old 09-24-2014 | 07:32 PM
  #2418
Tekno NB48
Price Reduced
$500 Shipped
PM me
Djameso is offline
Old 09-24-2014 | 07:54 PM
  #2419
madweazl's Avatar
Needed a few more goodies so I picked up 3x8mm titanium screws for the radio tray covers. Grabbed some 3x14mm for the servos and fuel tank as well since I had added the washers (figuring this would get me back to stock weight because I'm sure it will make a huge difference for me performance wise... ).
Nightfox body was sent off to Larry Genova for some paint, cant wait to get it back. I'm really tempted to order an XB9 Bitty Force body too but I dont want to waste any more money either. Sure like the way it looks though.
madweazl is offline
  #2420
Oh no, i dont need it but why are you selling it, its a great kit?
I've got two new in the box and figured someone with a little more time could put one of them to good use.
Money's also going to a good cause, my new helicopter that was $1500. Lol
Djameso is offline
Old 09-24-2014 | 08:09 PM
  #2421
Aluminum screws work great for those things and reduces twice the weight.
Djameso is offline
Old 09-24-2014 | 08:31 PM
  #2422
madweazl's Avatar
Yea, I found orange ones right after and ordered those. Forgot a couple things on the amain order and was able to add them along with some orange M3 and M4 nuts, the orange Durango turnbuckles, and most importantly, the Losi filter for the new body. There will be orange everywhere
The weight thing was purely a joke.
madweazl is offline
Old 09-25-2014 | 07:44 AM
  #2423
Graham11's Avatar
Its just money haha. I run the FTW xb9 body and love it but definitely need the losi air filter set up and takes some artful trimming to get the body right.
Graham11 is offline
Old 09-25-2014 | 07:49 AM
  #2424
madweazl's Avatar
What are the problem areas when it comes to trimming the body? I probably should have trimmed the body before sending it off to get paint to make things easier on myself. Maybe I should order another and trim it so I can trace the rough shape to the painted body.
madweazl is offline
Old 09-25-2014 | 08:39 AM
  #2425
Graham11's Avatar
Unfortunately you have to trim a lot off around the bottom edges and towards the rear. Nah you dont need to order another body, either way you have to trim it so dont worry about it, just wait until you get it back. I paint my own bodies and I cut it out along the guidelines as tho I was putting it on a xb9, I should test fitted it but I didnt, then I painted it and then tried mounting and found I had to cut at least a half inch off the bottom edges and really coulda done more and ended up loosing some of the details on the paint job but live and learn. Hopefulyl Pro-Line will make a NB48 body similar to the EB48.2 phantom body.
Graham11 is offline
Old 09-25-2014 | 09:16 AM
  #2426
Default Loose rear end
Im running Mo's set up and im experiencing a loose rear end on power. Its making it hard to push the car like I would like to. I really love the corner speed, acceleration and the jumping of this car. Mo was right it will out jump my MP9 and carry more corner speed. I was running with some of my friends last night and they all have mp9's. If I was behind them on the straight I was able to cut inside them going into the sweeper with some much speed. It was awesome. If I could just get rid of the car stepping out, that would be great. It does it with the slightest throttle input.
kpjr7321 is offline
Old 09-25-2014 | 09:34 AM
  #2427
Graham11's Avatar
Is your setup 100% exactly the same as Mo's setup? I ask because i definitely have not experienced the rear stepping out. Could it have been tire choice or just a really dusty track?
From Tekno Guide: Whenever you need more traction the first thing you should try (other than tires, which should always be the first thing to look at) is using your radio to de-tune your steering. Depending on your radio there are a few options to try. If your endpoints are set correctly simply turning down the radio’s dual rate can have a dramatic effect. The next thing to try is adjusting the radio’s exponential setting. Having a slight negative value (positive if you’re using a Spektrum) can help eliminate a loose or twitchy feeling. The last adjustment to try that not all radios have is a servo speed setting. Simply making your servo move slower can have dramatic effect. There are several ways to achieve greater traction out of a turn. The easiest adjustment is to either add a little toe out to the front of the car or add a little toe in on the rear. Another option would be to raise your rear anti-squat.
Graham11 is offline
Old 09-25-2014 | 11:21 AM
  #2428
The track was a little dusty but my D812 handled it nicely. I was running soft Impacts. I will def look into turning down my epa. Looking at Mo's set up what pills would I use to rise the anti-squat?
kpjr7321 is offline
Old 09-25-2014 | 11:40 AM
  #2429
You might want to check the washers inside the diffs to make sure they haven't warped, especially if you don't have the updated (black) ones in it.
ehartman_49348 is offline
Old 09-25-2014 | 12:35 PM
  #2430
Yes. I have changed to the black ones already. Im gonna look over the car to make sure nothing in binding up. I really love the potential of this car
kpjr7321 is offline
