Tekno NB48
#1666
So, my troubles with clutch continue.
Had not so long practice (about 3-4 tanks) with completely new shoes - 2x alu and 2x composite. Here are pics of them after run:
I dont think its normal. I've noticed that inner surface of clutchbell is not smooth at all, its very like damaged brake disc surface on fullscale car - grooved, ribbed and so. Maybe i need to replace my clutchbell instead of new set of shoes per every run?
#1667
After 2 races I sand down the edges of the shoes and put all back together.
I race 2 weekends a month. Hope this helps.
#1669
#1670
By the way, i love those protek sanding pens for sanding my clutch shoes:
http://www.amain.com/product_info.ph...ding-Pen-Set-4
#1673
Looks normal to me. I have found that the smoother I drive. My clutch has less wear. My clutch shoes are ready to be replaced after 3 to 4 race days.
My engine is Picco 5TR team spec with 2099 pipe (smoothest from all picco pipes).
Already ordered new clutchbell, and gonna make some experiments with old one.
#1674
Buku makes a 4 shoe? only thought they had the 3 shoe adjustable. you have a link?
#1675
#1676
going to have to find some of those!! I liked the wear of the Buku adjustable I had but i couldn't get the adjustment right. these would be great! I would probably stick with the 2 and 2 setup for springs. they should feel close to the same as stock but with much longer wear.
#1677
Anybody else have this happen? Ran buggy first race and it was great I was a full sec. Faster on fast lap and top 5 and 10 noticed my center diff leaking after so I opened it up changed fluid and retightend then it started spinning out all over the track. Started going thru everything and found the diff shims looked like this and my diff was locked up. Took shims out put back together and feels crunchy and stiff.
#1678
12Likes
