Official FlySky FS-GT3C thread
#46
GT3C User for 2 montsh here . Today when i just started drifting my rc the spring on the steering wheel which makes it return on the neutral position broke ... i contacted rcmart for the problem . Any ideas ?
#48
Tell me about the hack kit, what features does it give that aren't on the original software? I'm rather curious, thanks.
#51
I received one yesterday to go over for my brother. I ordered the green one from Hobbypartz.
I opened it up and started looking at it. Feels pretty good. I did check to make sure the power button did not need the mod and that it in fact had the bearing installed. So, the GT3C has 3 mods done for you compared the the GT3B. The C comes with the bearing, power button mod and a lipo battery.
Going over the charging. Was wondering why it came with 3 cables. You use the standard micro USB to charge it. WIN7 does not recognize it with the standard USB cable but does charge it. The LED light is red while charging, then it turned green when it was fully charged.
I then tried to use it with VRC. That is when I figured out you need to use the all 3 cables to use it as an input device. You have a USB to 3.5mm cable. It has a circuit board in it. You then plug the 3.5mm to USB female, then you plug the standard micro USB into that. Then WIN7 saw it as an input device and I was able to setup VRC.
I may get one just to mod and see what it can do with all of the updated firmware. For $50.00 it is well worth the money. Going from a RTR radio to this is a big leap of comfort and ease of programming.
Buzz.
Buzz.
#52
Buzz.
Buzz.
I managed to work it out with the help of the above post and have FS-gt3c working with VRC Pro perfectly, simple solution as above but mine did not come with extra cables so I just used a spare usb socket from old pc and connected green wire to tip of 3.5mm jack and black wire to earth of 3.5mm jack then plugged the 3.5mm jack into my Saili generic simulator and set it up on (g4,g5) (switch on side selects setting for different games, found this position works best) then connect other end with normal usb cable to transmitter... . Plug SAILi simulator into pc and let drivers load then just calibrate in windows game controller and you are ready to go.
Last edited by Stano71; 01-02-2014 at 03:26 PM. Reason: I worked it out. PPM at USB on FS-GT3C
#53
I thought it was funny how you have to use an adapter for the adapter to use the final adapter to get it to work. You need a bunch of cable to get it all plugged in.
Once you get it all plugged in, it does work. I have the it4, one cable and I am good.
Buzz.
Buzz.
#54
I'm still a bit confused by the whole adapter thing and getting the GT3C to work with VRC.
My GT3C only came with one cord. Has the USB on one end and the other end is much smaller and plugs in to the back of the GT3C.
I am running windows 8 and it doesn't recognize the controller at all. So that cable is just good for charging at this point.
Can anyone give me a little more help? It appears that I need another type of cable, can anyone point me in the direction for the cable I need?
thnx!
thnx!
#55
[QUOTE=Indetrucks;12912487]I'm still a bit confused by the whole adapter thing and getting the GT3C to work with VRC.
thnx
2Likes
