Team Associated TC4
#2266
Are you guys having to cut down tie rods to get them short enough to run shorter camber links? If not, what size tie rod are you running to run the shorter links? Thanks.
#2267
my turnbuckles are fine, and i just put 1 degree camber on all round, 0 toe on the front.
and i got tonnes of thread left (well that is in kit roll centre positions)
Dave, you got PM
Dave, you got PM
#2268
Later,
#2271
#2272
Thanks for the setup Dave
will give it a go this sunday and let you know how it goes
#2273
I wanted to experiment with the shorter roll center locations and the tie rods just seem a little too long to get the right amount of camber with the shorter the link. I didnt know if you guys were using a length other than stock, a buddy of mine shaved down some rods, just wondering if there was a way around it.
#2275
Re: BMI TC4 Chassis
Originally posted by protc3
hey guys,i will hopefully be testing it out on asphalt this weekend if i can kick this flu.the car is very stiff.i have had alot of good experiences with my tc3 chassis on asphalt with it being a 3mm chassis and top deck.it was a little more tough to get the car setup but when i got it right it was much faster than when i had it flexing with a 2mm upper deck.i think this tc4 kit is going to be a winner.lets see how carpet testing goes with ray.i will keep you posted on the asphalt testing.
#2276
tc4
hey guyz out of the box is the stock composite tc4 with high end electronics overweight or underweight?wat about the tc4 carbon fiber kit with high end electronics, overweight or underweight?any help well appreciated
Steven Alexander
Steven Alexander
#2278
Outdrive alternatives
I seem to be a little too tough on my stock plastic outdrives... I wreck, and they seem to get weakened and then my cvd bones will chronically pop out until I replace 'em.
I'm racing stock... so weight is a factor... what are the next-lightest, but more durable outdrives available?
IRS has aluminum ones... AE has lightened steel... anyone know how heavy these are and which are better?
thanks,
bob
thanks,
bob
#2279
tc4
hey man u race at mikes?i use to race there everyweek,very good store/track.lol every1 over there runs xray still?how many tc3s/tc4s?
#2280
Caster block revelation
Anyone ever notice how you can easily insert the small hinge pin into the stock castor blocks... but it's very difficult to insert the pin into the 4 degree blocks?
Well... since I assumed this part should be free-moving... i had gotten into the habit with my TC3 and TC4 of filing out the hinge pin hole on the castor block to make the pin move more easily.
However, I noticed that i had a bunch of slop in my TC4 front suspension... so i took a new 4 degree block a new polished hinge pin and just pushed the pin in really hard.... and it went in.
Despite this tight fit, the block still swings quite freely since the pin is rotating in the steering arm rather than in the caster block.
Anyway, thought I'd share... even though the pins are a hassle to get in and out.... some of my slop is gone.
