Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 03-27-2005, 07:28 AM
  #3766
Originally posted by raving-monkey
100 grams just by changing to graphite kit? i thought the graphite kit only lost about 30 grams..
By full graphite kit, I mean chassis, shock towers, A-arms, chassis braces, battery brace, steering knuckles, and rear hubs.
I forgot to mention such things as he's using a much larger esc (his TC2 vs. my GTX), 3600 batteries as opposed to my 3300's. I have rear composite dogbones w/ IRS lightweight outdrives, and I beleive he had all 4 aluminum blocks, while I only had the rear-toe block. Maybe chassis to chassis the graphite would only be 30g lighter, but lil things add up. Hope that clears things up a bit
Toodeep is offline
Old 03-27-2005, 08:14 AM
  #3767
raving-monkey's Avatar
ahh right, sorry...i must of read wrong (i thought it was 30 grams for the whole graphite kit, not just the chassis)
thats pretty cool, i won't be adding anytyhing like that onto my car though, as i see it to be pointless when i would be getting the FT TC4 when it comes out...and my car is going alright as it is
only thing i will most likely get is a 2deg rear toe block.
raving-monkey is offline
Old 03-27-2005, 08:21 AM
  #3768
CRASH's Avatar
Trader Rating: 26 (100%+)
Not only does the graphite kit lighten it up it also stiffens it up. A must for racing on the rug. As well as high bite asphalt.
Later,
CRASH is offline
Old 03-27-2005, 11:02 AM
  #3769
RCknight's Avatar
Default After market parts?
Seems there is some lacking support. I'm searching for some 3mm CF shocks towers for it. Anyone know where I can get them?
RCknight is offline
Old 03-27-2005, 11:06 AM
  #3770
Thanks guys!
So basically, a part from the weight you didn't really notice any benefits from the stiffness of the graphite kit (full)..?
I often heard drivers complaining about the lack of stiffness and probs with too much flex...how is the TC4 doing in big international races?
Cheers!
Tbevofreak is offline
Old 03-27-2005, 07:00 PM
  #3771
Paul_TC4's Avatar
Default Re: After market parts?
Try this: http://search.ebay.com/3racing-tc4_W0QQfromZR40QQsojsZ1
Hope that helps...
Paul_TC4 is offline
Old 03-27-2005, 08:02 PM
  #3772
Pretty sure www.rc-mushroom.com may have some CF towers for the TC4
MartynD is offline
Old 03-27-2005, 11:52 PM
  #3773
RCknight's Avatar
Default Thanks for hooking me up!
My only questions is are the CF towers 3mm thick?
RCknight is offline
Old 03-28-2005, 12:02 AM
  #3774
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Thanks for hooking me up!
PM sent your way about that Question
JDM_DOHC_SiR is offline
Old 03-28-2005, 12:43 AM
  #3775
fjm9898's Avatar
can you use the stearing block from the tc4 in the tc3 because with the open design on the tc3 i keep breaking them and the tc4 is one solid piece
fjm9898 is offline
Old 03-28-2005, 08:29 AM
  #3776
utieh's Avatar
Default Custom made carbon parts
I was able to take today some pictures of the carbon parts we designed for our TC4s, so far we have some 3,5mm side braces, they reduce the flex a lot but there is still some in the plastic braces area, a 2mm battery strap, it had been designed to be able to have some play so it doesn't tweak the chassis if the screws are a little bit overtight, some 2mm body mount plates, and 0,5mm, 1,0mm,1,5mmand 2,0mm arm blocks shims (We will take some pictures of them this week).
We would like to design a top deck but we really lie the open design of this car, probably a very thin one to reduce front to rear flex (with the side braces it barely have lateral flex)
utieh is offline
  #3777
utieh's Avatar
2nd picture
utieh is offline
Old 03-28-2005, 08:32 AM
  #3778
utieh's Avatar
sorry, here is the second picture
utieh is offline
Old 03-28-2005, 08:34 AM
  #3779
utieh's Avatar
one last pic.
utieh is offline
Old 03-28-2005, 09:55 AM
  #3780
fjm9898's Avatar
oops to correct myself.
i mean stearing rack, not block
can you the seating rack from the tc4 in the tc3?
fjm9898 is offline
