Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 03-13-2005, 10:05 AM
  #3616
Ortiz's Avatar
Can anyone tell me what adding washers to the steering rack ballstud does?
Ortiz is offline
Old 03-13-2005, 10:27 AM
  #3617
SMcpot's Avatar
Trader Rating: 22 (100%+)
Smile
Changes the Ackerman.....should make the steering more aggresive.
SMcpot is offline
Old 03-13-2005, 11:55 AM
  #3618
fathead's Avatar
Originally posted by Paul_TC4
Yup i'm really looking for that bracket. I know that IRS had them, but can't seem to find 'em. Know where I can find them?
Thanks.
K Factory make 2 different types of carbon plate shock tower for the NTC3 with aluminium adapters
www.kfactoryracing.com
the part no is K1239, you would have to cut off the piece on either side that is used to mount the upper arms on the NTC3 otherwise it is a dirrect fit
fathead is offline
Old 03-13-2005, 12:11 PM
  #3619
Fathead, do those fit the TC4?
Looking through that site, that aluminum steering rack looks sweet.
MartynD is offline
Old 03-13-2005, 12:21 PM
  #3620
fathead's Avatar
The shock tower adapters will fit on the diff housing as the TC4 uses the same diff housings as the NTC3 as long as you cut the upper arm mounts off the adapter, I'm not sure how the shock tower holes compare to the stock TC4 holes though, I will have a look when I get home tonight.
I don't know about the aluminium steering rack though, the TC4's rack is turned the other way compared to the NCT3 rack and I don't know if they are the same length, I haven't got hte aluminium steering rack but I will check the lengths to see
fathead is offline
Old 03-14-2005, 07:44 AM
  #3621
Formula1fan's Avatar
I have a TC4 on the way, I am picking up some things to build the car and had a question. The front bumper looks like it is the same as the NTC3, is it and will the RPM bumper work with it? Thanks.
Formula1fan is offline
Old 03-14-2005, 07:53 AM
  #3622
Default BUMPER
i use the rpm front bumper for the ntc3 and the tc4 foam, it needs a little modification but does work.
Rudedog55 is offline
Old 03-14-2005, 08:13 AM
  #3623
Old 03-14-2005, 08:57 AM
  #3624
Formula1fan
I use the rpm bumper , with some homemodified grommets (u will need the grommets from the ntc3 if you don't make your own)
I then took a foam bumper from an HPI nitro car that is much more dense than the AE and larger. I cut to fit and thats it. Not broken a front arm since doing this mod.
MartynD is offline
Old 03-14-2005, 11:20 AM
  #3625
Originally posted by MartynD
Formula1fan
Thanks. You should try a rubberneck bumper they are the best. Try sending a PM to Kevin he is on this form as wannabee.
Old 03-14-2005, 11:47 AM
  #3626
Heh well I have 2 foam bumpers already not including the stock one, and I was also asked to build one for another local racer.
I don't need any more +)
MartynD is offline
Old 03-14-2005, 11:56 AM
  #3627
Thats cool. I was just saying
Old 03-14-2005, 02:32 PM
  #3628
Hey F1, what email address do you have for Kevin? I ordered two more bumpers from him about six weeks ago and haven't received them yet. I wanted to get an update but my emails keep bouncing back. Here's the address I have for him. [email protected].
DOTMAN is offline
Old 03-14-2005, 05:01 PM
  #3629
I usually just wait and catch him at the track. He is a racing junkie and it's pretty easy. I should see him Weds. I will mention it to him. I usually pm him if I need anything.
Old 03-14-2005, 05:08 PM
  #3630
fathead's Avatar
Checked the holes on the K Factory carbon shock tower and they are comparable to the stock TC4 holes.
The outside hole on the carbon tower is a hole for a body mount but can be used for the shock, it is slightly lower than the other shock mounting holes but I can't see that being a problem unless running huge tyres
fathead is offline
