Like Tree4Likes
Viper RC -
Old 12-04-2013 | 06:22 PM
  #9436
Graham11's Avatar
Tried cleaning button... No luck.
I have a pro gauge, is that what u mean?
Graham11 is offline
Old 12-04-2013 | 06:26 PM
  #9437
MaplestreetRC's Avatar
no I mean the PC-link for connecting to a laptop or PC.
When all else fails I always reload the firmware. I'm not sure where else to go from here. The button is obviously working, because it turns on. For whatever reason it's not getting you to calibration mode.
Let me ask you, when you have everything off, and you press and hold the power button does the ESC cycle on into normal operating mode while you are holding the button?
What LED's are you seeing when you press and hold the power button when the ESC is off?
MaplestreetRC is offline
  #9438
Wildcat1971's Avatar
Tech Prophet
ok, I would try to reflash the esc and try again. If you have another radio/receiver I would try that also. if none of that works, I would try to rma it.
Wildcat1971 is offline
Old 12-04-2013 | 06:27 PM
  #9439
Graham11's Avatar
And when I power on and hold the button down it ends up just doing nothing when I let go, just the P light is on and I have to unplug to turn off
Graham11 is offline
Old 12-04-2013 | 06:29 PM
  #9440
Graham11's Avatar
What is reflashibg?
Graham11 is offline
Old 12-04-2013 | 06:34 PM
  #9441
What is reflashibg?
Just reloading the firmware.
That's weird man I'm sorry you're having trouble with it. Is it a new unit? I'd come by and take a look but PA is a long way off from AZ.
It sounds like it's not recognizing your radio is there. What receiver/radio are you using? Radio is on while you're trying to calibrate right?
Old 12-04-2013 | 06:36 PM
  #9442
Graham11's Avatar
Its not new, it worked fine in my other car, would wiring or a diff motor cause it? I also switched from Spektrum to Futaba and changed motor to d3.5 instead of Viper
Graham11 is offline
Old 12-04-2013 | 06:39 PM
  #9443
Graham11's Avatar
Would wiring or anything cause it? I also changed from Spektrum to Futaba and motor to d3.5, it worked fine in my other car, now it does do anything except servo works when power on.
Graham11 is offline
  #9444
See what you're describing sounds like a radio issue because it wont go into calibration mode unless the radio is on. When you turn it on with radio on do you have control? Everything is bound correctly? Correct model, etc
Old 12-04-2013 | 06:45 PM
  #9445
Graham11's Avatar
W radio on I can only steer, no motor. Its Futaba and I've used the same RX and trans before?
Graham11 is offline
  #9446
Tech Prophet
which firmware are you running. I had a similar issue with the a30 firmware. I upgraded to the a55 and it went away. Can you enter calibration mode with your old radio?
Old 12-04-2013 | 06:48 PM
  #9447
Try everything again in this order just to be safe Graham.
1. unplug battery from ESC
2. Turn on radio (be sure on correct model, etc.)
3. Plug in ESC
4. Press and hold power button atleast 5 seconds.
Might be able to get it to go, just by starting over like that.
Old 12-04-2013 | 06:49 PM
  #9448
Graham11's Avatar
Don't have old radio, I don't think I have the cord to plug into my computer?
Graham11 is offline
Old 12-04-2013 | 06:51 PM
  #9449
Graham11's Avatar
3. Plug in ESC
Tried this, no luck.
Graham11 is offline
Old 12-04-2013 | 07:01 PM
  #9450
Tech Prophet
which firmware do you have?
