Serpent 811E Buggy Thread >
Like Tree5Likes
Old 11-24-2013 | 01:11 PM
  #4366
Another method is using the nut or button head that holds the piston in place.
Depending on if you have the solid shaft using the flat nut or hollow with a button head.....with the shaft in the shock body use your hex driver or socket driver to hold the assembly as you screw the eyelet on.
Nexus is offline
Old 11-24-2013 | 01:56 PM
  #4367
rdeppen's Avatar
Needle nose vise grips and a rag. Never scratched a shaft using them for 18 years.
rdeppen is offline
Old 11-25-2013 | 10:03 AM
  #4368
Chad Millikan's Avatar
with my shock shafts and especially the tight turn buckles. I like to pre thread them by putting the shaft or turnbuckle in my drill on slow setting, and hold the eyelet end with a adjustable wrench on the flat part and thread it all the way up and down a couple of times. You end up getting nice straight threads. Just be sure to go slow so you dont heat up the plastic.
Chad Millikan is offline
Old 11-26-2013 | 10:34 AM
  #4369
What order do the inserts go in? For example, the stock rear toe insert is 6 out, so is there an insert that will give more toe out?
IOP_Racer is offline
Old 11-26-2013 | 10:48 AM
  #4370
Has anyone tried removing the battery tray and side guards all together? I took mine off and was thinking about a different way to mount batteries. Tekno makes some trays I'm debating on that only weight 25 grams so both would be 50 grams plus a couple for velcro straps. the stock versions with sideboards hardware and the carbon straps instead of doors weigh 160. 100-110 grams reduced sounds pretty good.
Gvm23 is offline
Old 11-26-2013 | 10:59 AM
  #4371
Maxxingout's Avatar
Why? Are you having some kind of handling issues or just looking to try something new?
Maxxingout is offline
Old 11-26-2013 | 11:07 AM
  #4372
Just trying to cut some weight! Plus a few of my batteries have leads that interfere with either style cover. Still waiting on everything I need to put it together.
Gvm23 is offline
Old 11-26-2013 | 11:09 AM
  #4373
The 6 insert is in the center =3º. 5in would give 2.5º. 4in would give 2º. 5out =3.5º. 4out = 4º.
There is a handy chart avaiable you can download on the serpent site for toe and antisquat.
jsorwell is offline
  #4374
Actually, 6 is centered and gives 3 deg rear toe in. 5 is offset a little, and can be installed in or out, to add or subtract 0.5 deg toe. 4 is offset more and is 0.5 deg more than 5.
Stealth_RT is offline
Old 11-26-2013 | 11:14 AM
  #4375
Maxxingout's Avatar
5 out will give you 3.5 toe and 4 out will give you 4 degree. 6 (stock) is 3.
Old 11-26-2013 | 11:51 AM
  #4376
So 5, 4, 3, 2, and 1 are each .5 degrees larger then the previous number?
Old 11-26-2013 | 12:04 PM
  #4377
Insert 0,1,2,3 is for the front
Insert 4,5,6 is for the rear.
http://www.serpent.com/product/600008/downloads/
Magnus F is offline
Old 11-26-2013 | 01:06 PM
  #4378
New body and wing, also got a m2c shock tower bra not impressed that I had to ream out the slot for the shock mount to fit through.
Gvm23 is offline
Old 11-26-2013 | 01:50 PM
  #4379
tkge's Avatar
Yeah I had to do the same thing to the two I got from M2C, one really didnt fit well at all, one did.
tkge is offline
Old 11-26-2013 | 02:01 PM
  #4380
Thanks for the link. That helped a lot.
