Official Tekin RX8 GEN2 ESC Thread
#1516
On the timing advance if I'm looking for the coolest run temp what setting should I use? Not looking for any performance gain out of 1900 or what is the timing advance number you like? I see the new one goes from 0-30. Would 3 be a safe bet?
#1517
Rx8 gen 2. I had a motor wire come off on the stand just checking things out. Car ran fine last week. No changes. I solder wire back. Now nothing. I have reset radio several times. Re blinded several times and even tried another rx. Same thing. Tekin gen 1 1900 spec dx3r. Any thoughts are appreciated.
#1518
#1519
Yes, 3 is good and default.
#1520
Codes look like this:
http://www.teamtekin.com/rs_troubleshoot.html
#1521
#1525
I am sure the app will be available the moment it has a company blessing. And I am also sure it will be known on this site inside of tern minutes later.
In the meantime we wait and they tease. And it is working. Interest is high.
#1526
#1529
#1530
I have a question on motor temps. I'm running the T8i 1950kv 16/45 gearing in a TLR 3.0, I'm only 204g over min. weight requirement. I run indoor medium size high bite clay. After a 12min run motor is 190f. Is this acceptable? I plan to cut 40g with a lighter battery. How much would this help?
20Likes
