Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 11-22-2013 | 09:40 AM
  #1501
motomatt's Avatar
JS70
Originally Posted by yzracer758
The Gen 2 will come with the EZ port adapter for the existing hotwire cable.
The Gen 2 can also be hooked up to the hotwire the conventional Gen 1 method
Instead of using the fan port, you can use the hotwire the same as the gen1 at the throttle connector.
motomatt is offline
Old 11-22-2013 | 05:50 PM
  #1502
mourinho's Avatar
Originally Posted by Randy_Pike
IF it's showing 12 67 you can open it up and dry it out. Rice, or a hair dryer will work fine. I recommend the latter.
Make sure it's 100% dry, hook it back up check your A B C wires for good connections. Make sure you're on motor type 1 2 or 3 and power it up.
Result?
I noticed that their was a ticking/clicking noise coming from either the motor or esc, I couldn't tell which, so I desoldered the motor and powered up the esc, no ticking no code.
Resoldered all connections and pulled apart esc to blow out and its all good.
Works flawless.
Cheers
mourinho is offline
Old 11-22-2013 | 07:49 PM
  #1503
silveraider14's Avatar
my fan connector doesn't fit in the fan port...
do I have to trim it down?
silveraider14 is offline
Old 11-23-2013 | 07:45 AM
  #1504
It will fit, but it's incredibly tight. I believe the statement was made they don't want it falling out, but it really is a bit excessive.
RokleM is offline
Old 11-23-2013 | 08:44 AM
  #1505
Ok I tried for a minute then put it down lol does the red go to the right or left?
Old 11-23-2013 | 08:48 AM
  #1506
RoketRdr's Avatar
Get a Dremel with the round sanding bit and go over the edges lightly. Works really well and making the connectors fit mo betta.
RoketRdr is offline
Old 11-23-2013 | 09:56 AM
  #1507
Rubiconmike's Avatar
Black towards the sensor port. it is tight. mine is in a dificult position at best.
Rubiconmike is offline
Old 11-23-2013 | 12:51 PM
  #1508
so glad i don't use the fans,
that tight fan port is no longer an issue as i just leave the hotwire adapter plugged in.
akshayp14 is offline
Old 11-25-2013 | 10:43 AM
  #1509
You're over geared for one. 6s 1400 on a TLR buggy should be in the 15-16 range on average to large sized tracks.
For the record those temps while on the warmer side aren't horrible. I'd like to see them lower as well and bet the gearing change will sort that out.
Your truggy is also over geared if you're running 17/45.
temps were worse with a 15t, motor up to 100 and esc 85 (this was on an even smaller tighter track)
i put timing on 1 thinking i'd be able to get longer run times and keep everything cooler, as i thought lower timing and higher gearing will give me more or less the same result as default (timing on 10), but it would be more efficient.
so my question is, for what im trying to achieve, would a better starting point be putting the timing back to 10 and keeping the 15t on? and will this keep my temps down?
Old 11-25-2013 | 11:28 AM
  #1510
also what is the minimum amps required for my setup?
wanted to try out a 2250mah 6s 65C but its only 146.25 amps
i assume the 2700mah 65c would be about the minimum (175.5amps)
Old 11-25-2013 | 02:37 PM
  #1511
USMC STONE's Avatar
I noticed the firmware was 246 on my new system but I updated with Hotwire and the latest available on there is 244. I'm gonna be running the RX8 2nd gen with 1900 in buggy so what's best firmware 244 or what came on it out of box 246 that I can't find on web site?
USMC STONE is offline
Old 11-25-2013 | 02:42 PM
  #1512
fq06's Avatar
The newest revision gives more control in datalogging and I think also the timing went from 1 - 100 to 1 - 30. I updated when I got it so I haven't had the first version of the RX8 G2 firmware to know for sure the timing was 1 - 100 like the G1 ESC. I know the newest is 1 - 30 to make more sense when adding timing up to 30°.
fq06 is offline
Old 11-25-2013 | 02:49 PM
  #1513
USMC STONE's Avatar
Cool, what are most running for the timing? I was thinking 0 or 10 I just want it to stay cooler not worried about power so should I run 0?
Old 11-25-2013 | 03:01 PM
  #1514
Randy_Pike's Avatar
Team Tekin
Yes.
Randy_Pike is offline
  #1515
Randy_Pike's Avatar
Team Tekin
We are set to release 246 here shortly. New units are already shipping with it.
