Team Associated B4.2 Thread >
Like Tree4Likes
Old 11-19-2013 | 08:28 AM
  #11266
Grasschopper's Avatar
Originally Posted by Grasschopper
I have a Lunsford camber/steering link kit that I'm going to install...it came with ball cups. Are they any good or should I not bother and just use RPM or the JConcepts kit I have?
Anyone? Quality of the Lunsford ball cups? Buhler? Buhler?
Grasschopper is offline
Old 11-19-2013 | 08:34 AM
  #11267
ryanpatrickgore's Avatar
lunsfords are great put em on. the studs are money!
ryanpatrickgore is offline
  #11268
DanielC.'s Avatar
If they are anything like the ball cups used with their TLR 22 set, avoid them like the plague. They would bend easy and were sloppy if you removed them just once.
DanielC. is offline
Old 11-19-2013 | 08:39 AM
  #11269
LOL...ok at least it's unanimous.
Old 11-19-2013 | 08:40 AM
  #11270
DanielC.'s Avatar
I'm talking about the BALLCUPS. The Studs and Turnbuckles are indeed "money". Ha!
DanielC. is offline
Old 11-19-2013 | 10:12 AM
  #11271
Originally Posted by 5th wheel
Okay thank yOu. I will study on it some more if you have a picture that you could post of this in your car that would be helpful assuming that you have the b4.2and the xerun v3.1 thanks for the help and info
Just installed my v3.1 yesterday. All I did was directed the wires toward the back and left just enough room for the sensor wire. Also brought the capacitor to the front.
lee111m is offline
Old 11-19-2013 | 10:31 AM
  #11272
2-shot's Avatar
I just got my body from E Z Customs, for my B4.2. I had a question about mounting it. Should I use the Velcro on the side of the chassis method, or should I drill holes and use the rear body post and the screw in the front? I would rather go the Velcro route, but I wanted to get some opinions first. If the Velcro method is the way to go, any tips I should know before doing it?
Thanks for the input!!!
Oh, here's a pic of my body!!!
[IMG][/IMG]
2-shot is offline
Old 11-19-2013 | 10:48 AM
  #11273
Velcro...no real special tips. I use about 5 inches per side in three sections on each side. The front angled in area, the side and the rear angled back area. Done.
If you look close to the left side of this photo (right side of the car) you can see the front and side applications...the rear is out of site because of the angle.
Old 11-19-2013 | 12:04 PM
  #11274
blade329's Avatar
Any special tips on mounting the Velcro inside the body? Every time I have tried Velcro they would inevitably come loose on the body.
blade329 is offline
Old 11-19-2013 | 12:08 PM
  #11275
Tyler Keel's Avatar
Make sure the inside of the body is clean where you're putting the velcro and I usually always heat up the adhesive with a lighter before sticking it on anything.
TK
Tyler Keel is offline
Old 11-19-2013 | 12:43 PM
  #11276
the incubus's Avatar
Not sure if anyone else has come across this but I was looking for a sheet of CF to do some customization of my own and came across this and found it rather interesting!!!
All info on this is located here:
http://www.rc10talk.com/viewtopic.ph...rt=180#p359505
the incubus is offline
Old 11-19-2013 | 12:56 PM
  #11277
rc car guy's Avatar
Hm too bad its for shorties only
rc car guy is offline
Old 11-19-2013 | 01:17 PM
  #11278
blade329's Avatar
TK
Thanks. I will try that.
blade329 is offline
Old 11-19-2013 | 01:55 PM
  #11279
silveraider14's Avatar
that's made by one of the locals! I have held it! it indeed is awesome
im not sure if he ran it like that but I think it was on the heavier side. deffinetly heavier than the plastic chassis
silveraider14 is offline
Old 11-19-2013 | 02:13 PM
  #11280
Speed Freak RC's Avatar
I am sure the design could be lightened a little bit, but it just looks so clean. I would buy one for sure. Very trick looking.
Speed Freak RC is offline
