Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 11-05-2013 | 10:38 AM
  #1396
Randy_Pike's Avatar
Team Tekin
Originally Posted by Rubiconmike
so I wired up the Rx8 Gen2 and ran the 4600 motor man is it smooth.
the Fan. it only comes on for a second then shuts off.
Is it on a thermostat? it only runs when things get hot?Yes it's temperature controlled via default.
can you control the fan with the hot wire? (on order)Yes
Thanks.
There's no reason to cover the solder posts, fyi. I prefer to see the solder joints as I've found more often than not that this jont can fatigue and "hide" connection issues in the shrink wrap.
Randy_Pike is offline
Old 11-05-2013 | 11:09 AM
  #1397
fq06's Avatar
Originally Posted by Afun
Is it worth the upgrade? Or wait until the Generation 1 breaks and then buy it?
IMO, not really. I'm sure the pros or even the regular club racers that are at the track a few days a week may be able to feel that the gen2 is smoother. But for me, the gen2 just needed a little less curve to get the feel I like compared to the gen1.
If you have a HV servo, its worth it. You can set it for normal 6v bec or 7.4v bec.
If you have a savox TG servo... probably worth it, 7a bec.
If you can get $100 for your gen1 and put that towards the $200 gen2, that's something to consider. Once your gen1 fails I think its a little more than $100 for the upgrade so you would come out ahead if you sold a working gen1.
Randy, I know I saw it before but don't recall, $160 or something for the upgrade if you don't have the parts to repair a gen1 sent in for service?
fq06 is offline
Old 11-05-2013 | 11:19 AM
  #1398
Randy_Pike's Avatar
Team Tekin
$123
http://www.teamtekin.com/Forms/Service_Request_Form.pdf
  #1399
Afun's Avatar
I have KO Propo BSX. It's already to dang fast 6.0. I will just keep like that and wait to purchase this new. Thanks
Afun is offline
Old 11-05-2013 | 12:31 PM
  #1400
fq06's Avatar
Originally Posted by Randy_Pike
That's not bad. You will see one of my gen1's come in soon.
Funny thing... had a backup gen1 forever and haven't needed it (I think almost 2 years now).
Let my buddy use it because his brushless hobbies fried.
What do ya know... that same day I finally needed a backup ESC
Positive bullet came unsoldered, wire was old and should have been replaced a bullet swap out or two ago.
No smoke, no smell, new power wires... would not power up.
Removed switch, still no power.
Bought a gen2 to finish the day, same wires that were on the ESC I was changing out.
So I guess I will upgrade my gen1 to a gen2 and sell my other gen1 when my buddy is done with it or he can just buy it from me... probably his best option.
fq06 is offline
Old 11-05-2013 | 03:46 PM
  #1401
Ah, are you using a Gen2 esc? Programming through the port? What PC are you using?
Yes both are fresh gen 2. Using samsung laptop on windows 7. I am programming through the fan port.
JS70 is offline
Old 11-05-2013 | 04:48 PM
  #1402
Randy_Pike's Avatar
Team Tekin
2 things.
Be sure to go and download the latest software :www.teamtekin.com/hotwire.html
We just released a new version.
Also note that you must insert the programming cable into the port, STRAIGHT.
Please update your Hotwire to the 9.8.5 and retest.
Old 11-05-2013 | 05:19 PM
  #1403
Rubiconmike's Avatar
The fan is temp controlled, it comes on for a second then turns off. If your temps get up to where the ESC wants it, it will turn on.
You can change that to always on in the hotwire program.
Cool thanks for the info.
Rubiconmike is offline
Old 11-05-2013 | 05:50 PM
  #1404
I figured that the shrink wrap would help support the
Solder joint. Less chance of fatigue.
I'll consider cutting it off.
This kit was built for just 4 races in our
Winter races then full tear down till summer.
It's going to be cold. No heat. -3c or so.
Old 11-07-2013 | 06:04 AM
  #1405
Hey everyone,
I need advice please. Just wired up my rx8 gen 2 in my E 3.0 last night, without having the my 1950 t8i hooked up yet. My savox 1256tg servo was seeming to have brown out issues. Never had a problem before using an Orion esc with the same servo. Moving the wheels left to right fast it locks up for a second and all the LEDs on the rx8 blink. Instructions say receiver is losing power, is that a brown out? I welcome any suggestions. Thanks
old carpet rcr is offline
Old 11-07-2013 | 06:22 AM
  #1406
fq06's Avatar
Sounds like a brownout, do you have a cap to throw in the RX to try your test with again?
fq06 is offline
Old 11-07-2013 | 07:38 AM
  #1407
No, never had this problem. I saw plug in ones on A main, is there a certain one I should get?
Old 11-07-2013 | 07:47 AM
  #1408
yzracer758's Avatar
Team Tekin
Spektrum: Part # SPM1600
Also have you tried upping the BEC voltage in the RX8 via the hotwire to 7.4v?
yzracer758 is offline
Old 11-07-2013 | 08:02 AM
  #1409
TY@TEAMTEKIN's Avatar
Team Tekin
Thanks.
Also, I don't think anyone mentioned, but your fan is mounted upside down. Always mount sticker side down.
TY@TEAMTEKIN is offline
Old 11-07-2013 | 08:28 AM
  #1410
Thanks Ty. As soon as it was powerd up
I flipped it.
Man you guy make some good stuff.
Smooth. Thanks.
