Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 11-11-2013 | 11:28 AM
  #1426
fq06's Avatar
Originally Posted by mydudrevo
Anyone?
Service request form says if past 4 months its out of warranty, doesn't decipher between motor or ESC so I would guess that applies to both.
fq06 is offline
Old 11-11-2013 | 02:24 PM
  #1427
Randy_Pike's Avatar
Team Tekin
Anyone?
120 days from date of purchase.
Randy_Pike is offline
Old 11-13-2013 | 12:23 PM
  #1428
Default hot wire woes
have had this esc for three weeks, lacks the punch my castle had. So I figure hook up the ole hot wire, and tweak her a bit. Hell no problem.
Well yes there is a problem, I OWN A DELL. After finally getting a chance to call the guys at tekin, that's the answer I get. I hope they can resolve this issue I will get rid of the rx8 before I get rid of the computer. I'm sure its a good esc, but if I can't reset things to my liking to at least match what my castle did, then it has no point. Castle seems to have no problem working on a Dell?
BGCustoms is offline
Old 11-13-2013 | 12:30 PM
  #1429
fq06's Avatar
Hopefully the mobile app will be ready soon and you have an android phone or other device that you can use for hotwire.
You can also use the quick tune buttons to add timing.
fq06 is offline
Old 11-13-2013 | 12:58 PM
  #1430
yzracer758's Avatar
Team Tekin
Your Hotwire will work with a Dell, put the computer into Safe Mode and it should be good to go.
yzracer758 is offline
Old 11-13-2013 | 01:16 PM
  #1431
Safe mode still doesn't work, Tekin software not available in safe
Old 11-13-2013 | 01:41 PM
  #1432
yzracer758's Avatar
Team Tekin
It must be something else then... If you want to call in and talk to our software Tech. I am sure he will be able to get it squared away for you.
Old 11-13-2013 | 04:43 PM
  #1433
beidle99's Avatar
It has to be something else. I'm using an old dell that runs XP and it runs the hotwire software fine.
beidle99 is offline
Old 11-13-2013 | 04:50 PM
  #1434
RiceP's Avatar
Yeah I am also using a cheap dell desktop from Walmart and a dell laptop for track tuning and have never had a issue works great on both
RiceP is offline
Old 11-13-2013 | 04:59 PM
  #1435
I use one of the original 10 inch Dell netbooks. Works perfectly.
Mullet1 is offline
Old 11-14-2013 | 05:08 AM
  #1436
mine is a newer machine only 6 months old, same issue on a newer gateway as well. I am very computer savy. there is nothing wrong with my system. More disappointed with the lack of support. Get more of a ohwell better luck next time. They could have at least posted this as a known problem on their site. Racing is something me and my son have done for a few years. I use it a a therapy to help treat my autistic son. Safe mode at the track turns off every thing else he uses. Will be going back to Castle.
Old 11-14-2013 | 07:08 AM
  #1437
Randy_Pike's Avatar
Team Tekin
We're here to give support. Clearly you're not taking advantage of it or not asking the right ?'s.
The Hotwire works on Pc's running XP, Vista, Win 7 and Win8(most versions).
So what OS are you using? Hit us up at [email protected] or our livechat and I'm confident we can sort out the issue.
The most common issue on a "new" Pc is the .net framework doesn't have the 3.5 version installed which is required. The 3.5 can be download from Microsofts website.
Old 11-14-2013 | 08:30 AM
  #1438
lbenton's Avatar
Did not know .NET was needed, but then again did not notice as it ends up on most systems given some time anyway as something will require it along the way. Does the installer look for prerequisites? A link to the .NET page on your website would be helpful, or if there is a link already making it more prominent?
And how long before we get to use Door #2, I am ready to use my android tablet, I got my OTG host adapter off Amazon just the other day hoping for good news soon.
lbenton is offline
Old 11-14-2013 | 09:08 AM
  #1439
Randy_Pike's Avatar
Team Tekin
There are links to this issue and it's correction in ouf FAQ area and troubleshooting
Door #2 is close....
Old 11-14-2013 | 10:15 AM
  #1440
Clearly I haven't taken advantage of the service? I was told by Jeremy that there was no fix. Nothing is noted about this problem. What more could I ask? I asked Is there a way I can get it to function as it should. Clearly this problem is mine, Clearly the service either could not or didn't have the resource to assist with their product. I would even have accepted we are currently working to repair the software issue, keep an eye on the site when the updates are ready.
