Team Associated B4.2 Thread >
Like Tree4Likes
Old 11-03-2013 | 05:17 PM
  #10966
silveraider14's Avatar
Dremel with a drill bit lol
I just made the hole big enough to put the whole plug through
silveraider14 is offline
Old 11-03-2013 | 05:57 PM
  #10967
2-shot's Avatar
Hey guys! I'll be running my B4.2 on a medium sized indoor track. I'm going to run a 13.5 motor on it. What would be a good start on gearing for it?
The track is more technical with smaller jumps.
Thanks in advance for your help!
2-shot is offline
Old 11-03-2013 | 06:03 PM
  #10968
2-shot's Avatar
All of the small diameter drill bits that I break, gets used in my Dremel. Drill bits chucked in a Dremel makes a great cutting tool for plastic!
I haven't cut the holes in my chassis yet, but I'm sure I'll use a Dremel with an old broken drill bit to slot it out for the plugs to go through.
2-shot is offline
Old 11-03-2013 | 06:13 PM
  #10969
Well the Jconcepts ones look good and im guessing they work pretty well. Im a big jconcepts fan and havnt been let down yet.
Last questions, if i go over to BB springs do i need to change out my shock towers to b4.2 ones or are my current ones fine?
Thanks for the info guys
JoshC90 is offline
Old 11-03-2013 | 06:28 PM
  #10970
Wildcat1971's Avatar
Tech Prophet
should be fine
Wildcat1971 is offline
Old 11-03-2013 | 07:35 PM
  #10971
Wild Cherry's Avatar
[QUOTE=JoshC90;12692597
Thanks for the info guys[/QUOTE]
will need to add 2mm spacers if using 12 mm shock & old b4 tower.
check out the info for installing the 12mm shock on www.rc10.com
Wild Cherry is offline
Old 11-03-2013 | 08:27 PM
  #10972
mip top shaft vs avid top shaft?
xTotalghost is offline
Old 11-03-2013 | 08:40 PM
  #10973
rc car guy's Avatar
i have heard that the mip one is the best one, also its exactly 4.0g and i have it i like it a lot reduce motor temp 10 deg
rc car guy is offline
Old 11-03-2013 | 08:43 PM
  #10974
the avid one is 4 grams
Old 11-03-2013 | 08:58 PM
  #10975
rc car guy's Avatar
well i remember reading somewhere on here that a couple of guys have gotten a few bent ones but at this point i think its your preference
Old 11-03-2013 | 09:34 PM
  #10976
What do you guys think about the MIP puck stytem?
Old 11-04-2013 | 05:41 AM
  #10977
rc car guy's Avatar
well sorry for "over" posting but i also know about that haha. The sponsored guy at my track his buddy tested it for 2 months and said it was good an it should aprox remove 30g of weight from your car, however 90 bucks i think not, however if you got that kind of money go for it
Old 11-04-2013 | 07:56 AM
  #10978
People say the parts wear out a lot faster is it true, and what if you use it in a mod vehicle?
Old 11-04-2013 | 08:05 AM
  #10979
Grasschopper's Avatar
Not sure why people keep saying $90 for the Pucks system...MSRP maybe? AMain has it at $68...which still isn't cheap but it isn't $90 either.
It's not for mod racing...don't use it in a mod car, the mod car has plenty of power to spin up the drivetrain, the 17.5 being "power limited" gains a benefit from the lighter drivetrain.
Grasschopper is offline
Old 11-04-2013 | 10:15 AM
  #10980
bilster44's Avatar
I wonder if you HAVE to use their "grooved" thrust washers in the diff?
bilster44 is offline
