Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-07-2013 | 07:29 PM
  #10216
Dan Hamann's Avatar
Originally Posted by jswo
I'll try again
It could be any number of things, none that can have a direct answer.
Spring tolerances
Different foam desnity
Different tire weights
False sense of "balance" because of inline
etc.
To expand on the last one, in-line doesn't mean everything is perfectly centered. If you have the wire routed slightly to the left rear of the car (you do, that's where the motor connections are), you have an imperfection in weight.
Less than 20gr off to one side of the car or the other? I wouldn't worry about it.
Dan Hamann is offline
Old 10-07-2013 | 07:33 PM
  #10217
vr6cj's Avatar
Originally Posted by TomErickson
Where are you seeing the B4.2 on special? All I see is the web special B4.1 with Big Bore shocks. Please provide link.
just scroll down on that page u where at.
but here's link to it. on sale for 259
http://www.teamassociated.com/parts/details/9041/
vr6cj is offline
Old 10-07-2013 | 07:47 PM
  #10218
Gene158's Avatar
Originally Posted by Wildcat1971
Have you tried CC in the rear? And if your on a high bite track, the c-hub with the shaved brace might give you the added side bite you want. I mention the CC in the rear, because maybe the tire is deforming coming out of the corner under power.
CC as in closed cell foam?
Gene158 is offline
Old 10-07-2013 | 07:48 PM
  #10219
Gene158's Avatar
Originally Posted by DanielC.
I'd start with moving your rear shock in on the bottom and dropping to a green spring. Many like green F/R with 32.5/30
Undo those changes you made to the camber links and wheelbase.
I will try that. Thanks.
Gene158 is offline
Old 10-07-2013 | 07:51 PM
  #10220
Wild Cherry's Avatar
Tech Legend
G wiz ????
You guys haven't seen the new car yet ?
Lol
Wild Cherry is offline
Old 10-08-2013 | 03:37 AM
  #10221
Jstall7543's Avatar
Originally Posted by Gene158
Someone please HELP!!! I'm in desperate need of some more setup help. My buggy seemed to be working pretty well but I now switched from a 17.5 to a 7.5 motor. The car is not handling well and I was pretty frustrated today trying to drive/tune it. Part of the issue is the fact that I'm getting used to he power but even once I got comfortable, it handled like $hit. The rear end is very loose especially when exiting corners. It's very hard not to spin out. I am running 0 anti squat, moved the rear hubs all the way forward and I moved the rear camber link to the 3rd outermost hole on the hub. The track is med-high bite but can get dusty at times. I'm running the correct tires as well as a full size batt pack.
I like to use throttle expo on my radio as a traction control on all my mod vehicles. By adjusting the expo you can increase or decrease the trigger sensitivity but still have full power when you punch it. Even a sensored mod motor delivers power so abruptly that it can be difficult to tame in 2wd. I just built a new kit and put a 7.5 in mine and I had to immediately adjust the expo for the track conditions and my shortie lipo light weight setup. Try it, its one of my speed secrets I use on a regular basis. When other people are complaining about traction, I've alread made a adjustment to compensate and they ask what tires I'm running I say MC ions with buggy grip.
Jstall7543 is offline
Old 10-08-2013 | 03:45 AM
  #10222
Gene158's Avatar
I actually did mess with the expo. I'm at -2. What do you run yours at?
Gene158 is offline
Old 10-08-2013 | 03:46 AM
  #10223
Jstall7543's Avatar
Originally Posted by Wild Cherry
G wiz ????
Lol
Ya I've seen it but I'm still not convinced mid motor is better after the experience I had with my 22 considering B4.1 and 2's where running circles around me. I literally tried everything with that car in both configurations and my laps were faster on my first 2 batteries with the b4.2 kit setup.
The centro looks legit but hows it doing in Tacoma? I heard scotty has one.
Also is the centro running standard saddle packs or the larger 1s packs?
Old 10-08-2013 | 04:47 AM
  #10224
rc car guy's Avatar
I liked the shaved brace/ c hub even on a lower traction surface, it just feels better to me
rc car guy is offline
Old 10-08-2013 | 04:50 AM
  #10225
rc car guy's Avatar
if your running you can also run "traction control" or throttle speed, with the 4pk's go into your menu and then if your on menu two press plus and then go into throttle speed, pres the plus to get to setting three, go down and set the first to like 75% and the 2nd at like 90% and the third at 100% unless you want to limit your speed, dont change 3
Old 10-08-2013 | 04:54 AM
  #10226
Wildcat1971's Avatar
I didnt. The cars rear end stayed too flat and skated a lot.
Wildcat1971 is offline
  #10227
Spring tolerances
etc.
I weighed it before the centering kit and it was closer. I thought it was supposed to center weight better, maybe i'll try the receiver on the other side. Also why is the front off more when basically everything in the front should weigh the same? Can I make changes other than adding weight?
jswo is offline
Old 10-08-2013 | 05:27 AM
  #10228
rc car guy's Avatar
first off this isnt a touring car. Look where all your weight is (in the rear motor, battery, receiver, wires, diff,tranny etc, the only thing you have up front is your servo, and steering rake
Measure your cars weight left to right (which is what the centering kit does makes it more even left to right) if they are with in about i dont know 10 grams your fine, you can play with wire placement, or moving your transponder around, but if its close your good, i doubt youll notice a difference between moving the reciever and transponder around unless its center lined, compared to on the outsides, just run it see how you like it
And i think its a matter or preference, we have big sweepers, and wide corners at our track, it worked well wet or dry, but it also depends on the rest of your set up, i didnt bother changed it back to the a tower because i thought it worked well 3rd time racing the buggy and i got first or 2nd i dont remember
Old 10-08-2013 | 05:40 AM
  #10229
Grasschopper's Avatar
I don't know if anyone saw my post a little way back but I'll try again. Yesterday I put in the AVID centering kit and now my buggy is around 15gr heavy on the right front and 4gr on right rear. Also I have the esc on shelf , the only thing on right side is a 4pks receiver ( very light ) everything else is centered. Also I took it apart and cleaned everything so I know its not dirt causing the problem, also checked shock collar height with calipers. Any help would be great.
Ok so I just weighed my B4.2. Bit of info, I also just installed the AVID centering kit (didn't weigh it before) and also went centerline with the ESC in the tray. My RX and transponder are on the right side of the car. I'm running a shorty.
LF - 206g
RF - 220g
LR - 459g
RR - 463g
I haven't measured my spring collars yet, I'll do that shortly...honestly I should have cleaned it a bit first too as there is some dirt build up. Also noticed that my LR shock is leaking where all the others are pretty good.
Edit: so I think I need to rethink my measurement technique as my total weight by adding those numbers is 1348g and when I measure the total weight it is 1485g. And to add to that...does it make sense that I'm at 1485g without the body? Thought I should be heavier...didn't bring the body to work so I'm not sure what it weighs.
Grasschopper is offline
Old 10-08-2013 | 06:20 AM
  #10230
Originally Posted by xTotalghost
What if I use the stainless on everything but on the shock and suspension use titanium
I would think that would be ok.
Here's my exact setup (attached). As I said before, the rear end is very loose.
Here's the setup I used this past weekend. Outdoor, dusty 1/8 track that's pretty bumpy. I had made several changes here and it worked VERY well as opposed to the traction I had been having. I was all loose in the back as you describe but with this setup I felt pretty locked in and my times improved as the day went on and I got used to a revised track layout. Wound up 3rd in the final race. I guess my thoughts would be more rear toe and some additional negative camber as well as making sure you are transferring weight to the rear wheels.
Attached Thumbnails Team Associated B4.2 Thread-screen-shot-2013-10-08-9.19.02-am.jpg
