Like Tree5Likes
SC10 4x4 Thread
Old 10-28-2013 | 10:49 AM
  #35521
Cain's Avatar
You should submit that setup to AE. wouldn't be surprised if it gets posted on the website.
looking forward to videos of the sc10 4x4 on this track.
Cain is offline
Old 11-01-2013 | 02:10 AM
  #35522
I got my Exotek LCG chassis installed and it does add a good amount of weight to my truck.
rippen is offline
Old 11-01-2013 | 09:07 AM
  #35523
Cain's Avatar
cool. Let us know how it works out for you. Was very happy with mine.
Cain is offline
Old 11-01-2013 | 09:18 AM
  #35524
MantisWorx's Avatar
+1
MantisWorx is offline
Old 11-01-2013 | 10:14 AM
  #35525
GraphiteChassis's Avatar
Rippen, where in Commerce do you race? Is Larrys still there?
What about the Riders Hobbys carpet stadium in Livonia?
GraphiteChassis is offline
Old 11-01-2013 | 12:31 PM
  #35526
Wilds Sc10 4x4 set-up
Front
Yellow sway bar
1.2 piston , Yellow spring, 35W , no internal limiter, emulsion cap seal, bar flush with sway bar socket
shock location = middle on tower & outside on arm
camber location = inside on tower, 2mm spacer under stud , 0 bump steer
body mount = #2 hole
20 T front pulley
Clicker full time
20mm ride height
1 1/2 degree camber
1/2 degree toe in
Optional Team steering rack , rear stud hole
Belt tension = tight
Rear
Blue sway bar , push bar far as you can into sway bar socket, a little nub of the bar should show on the outside of socket.
1.2 piston ,yellow spring, 30W, no internal limiter,emulsion cap seal,
unscrew shock eye 1 turn
Shock location = outside on tower, inside on arm
Camber link location = middle hole on hub , inside hole on tower, 6 mm spacer under stud, use rear camber mod
#1 hole for body mount
20 T pulley
20 mm ride height
1 degree rear camber
decouple slipper
belt tension = tight
3-2 toe block
Rear hub position = middle on arm
Reedy 4.5 550 Sonic , 12T/62S, 20D timing
Quad pad VTS slipper , heavy duty pad on back side of spur , 3 VTS pads on outside, adjust lock nut 1 turn from being flush with top shaft.
Reedy 4100 60C shorty, middle of chassis , foam blocks on the sides, LRP FLOW ESC, use the fan.
Ae XP 1015 steering servo
30K front diff oil
7k rear diff oil
Chassis brace
Chassis weight = 1 1/2 oz on each side of steering servo
Front Tire = JConcept Gold Pressure Point
Rear Tire - JConcept Gold Bar Code
Trinity Black dot tire compound ,* only use on rear tire.
Body = JConcept FLOW , PINK , vents cut out
JConcept rims
track conditions
Indoor clay , med traction , smooth, dusty, big 1/8th jumps
Qualified 3rd A main, placed 2nd ....
zero AM parts needed or used ...
Great detailed setup there Wild Cherry... except those JC wheels, I take it they are +3's?
Race Results (actually finished 3rd) LOL
3 of the top 6 were SC10 4X4 (me too).
Sofa King is offline
Old 11-01-2013 | 12:52 PM
  #35527
Mainly Dirtburner's in Livonia and Washtenaw. Livonia is where Dirtburner's moved to so they could have an indoor track for winter, it's a great place to race.
rippen is offline
Old 11-01-2013 | 03:50 PM
  #35528
Wild Cherry's Avatar
King
yes , wide yellow JC rims ...
Tires were kick down & had decent thread .
Can't wait to go back . I even worked on the PINK yesterday.
Going to try some custom flat pistons & 1/2 weight up on the oil for better landing off that triple.
Wild Cherry is offline
Old 11-01-2013 | 03:52 PM
  #35529
King
More like mud them oil inside .
BTW
Lost a piston on the rear shock in the main, rest were way loose as well.
Old 11-01-2013 | 05:15 PM
  #35530
Bubben's Avatar
Help please.
I have SC1200-bl Brushless esc
So I have done the calibration and programming but cannot get reverse to work. Great for racing but not so handy when bashing around with kids. Plus I paid for it so I want it.
I am sure that there is some trick that is simple that I am missing. Any help would be great.
Bubben is offline
Old 11-01-2013 | 05:33 PM
  #35531
Cain's Avatar
Sofa King, What was your setup as I believe you were using the Center Diff and which one is you on the sheet?
Also, what was being run by the top 2?
Cain is offline
Old 11-01-2013 | 06:40 PM
  #35532
....Lost a piston on the rear shock in the main, rest were way loose as well.
Funny...I had a rear shock go out in the main too!
Old 11-01-2013 | 07:20 PM
  #35533
Tuff racing still had good time.
R they doing a track change soon ?
Old 11-01-2013 | 07:42 PM
  #35534
See attached setup sheet. I was #6... truck not holding me back, lol, I'm holding it back.
I know #2 was Losi and think #1 was also, but not sure. #5 was other SC10 4X4.
Old 11-01-2013 | 07:44 PM
  #35535
Track change end of November.
