Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-17-2013 | 02:58 AM
  #10546
weyant's Avatar
Got a b4.1 that I have just about got completely upgraded to the b4.2 but the VTS slipper and im have trouble getting the it to work right seems like the shaft is to short to allow you to tighten the slipper nut down at all its barely on and I didnt like that whats the prob?
weyant is offline
Old 10-17-2013 | 03:50 AM
  #10547
F18engineguy's Avatar
Make sure your stack up is correct and if so you need to compress the spring a bit
F18engineguy is offline
Old 10-17-2013 | 03:53 AM
  #10548
Jstall7543's Avatar
If it's a new spring you need to hold it firmly and compress it a few times with pliers. It's in the b4.2 manual. Standard procedure.
Jstall7543 is offline
Old 10-17-2013 | 06:58 AM
  #10549
rc car guy's Avatar
I made the same mistake the first time i built my buggy seeing as touring cars dont have slippers haha um the the spring like compress a few times, and the black spacer make sure you have it so that flat side is towards the outside against the nut
rc car guy is offline
Old 10-17-2013 | 09:50 AM
  #10550
EvanAZ's Avatar
Hey All,
Looking for some parts to finish a couple more builds for our program.
Still looking for
Ball studs
b4 turnbuckles
front top plate
servo mounts
T plate
bearings
Tranny parts, slippers/layshafts etc.
Anything for a B4/T4 or SC10 would be helpful.
http://www.rctech.net/forum/r-c-item...1-10-road.html
EvanAZ is offline
Old 10-17-2013 | 12:08 PM
  #10551
Can someone tell me the difference between the broached balls studs compared to the silver ball studs.
isarctard is offline
Old 10-17-2013 | 12:23 PM
  #10552
The broached ball studs have a hex broached into the top of the ball, allowing the use of a hex driver for installation and removal.
parallelfish is offline
Old 10-17-2013 | 02:38 PM
  #10553
Jstall7543's Avatar
Anyone ever try the jconcepts B4 front wing on a tight indoor track? How it work out for you?
Old 10-17-2013 | 09:58 PM
  #10554
rc car guy's Avatar
I am too interested about it i tried to find what it does or how if effects handling even asking jconcepts themselves (no reply) so im not sure i was going to try and make one out of some lexan i have but i just havent gotten around to it
Old 10-17-2013 | 10:06 PM
  #10555
i1justin's Avatar
make sure you are using the right spring. if you bought a vts kit do not use that spring it is too long, you need 9739
i1justin is offline
Old 10-17-2013 | 10:54 PM
  #10556
Don't think I'll be reversing polarity anytime soon....
ntJeff is offline
Old 10-17-2013 | 11:00 PM
  #10557
Oh man if you put them in backwards ur car goes faster!!!!!
xTotalghost is offline
Old 10-18-2013 | 06:35 AM
  #10558
Yeah, it goes faster backwerdz
theblitzkidd is offline
Old 10-18-2013 | 06:42 AM
  #10559
Does anyone have a good starting point for oil in a gear diff? High bite indoor clay (OCRC) running 7.5 mod. Thanks.
goin2drt is offline
Old 10-18-2013 | 06:48 AM
  #10560
Wattsup23's Avatar
from what i have read around 2,000cst diff oil seems like a good starting point.
Wattsup23 is offline
