Team Associated B4.2 Thread
Interestig battery...... i guess it will work well in the sc 4x4 and the C4.2
http://www.teamassociated.com/news/l...n_LiPo_Battery
the tapered piston, the taper goes towards the bottom of the shocks right?
also what would be a baseline oil I was thinking about running 1.4x3 tapered in the front and 1.6 flat machined pistons in the rear. Med size track pretty smooth clay type surface
I've seen people use anywhere from 27.5 to 35. You could probably start at 30 and see how it feels?
I tried out the o-rings recommended by mick33b4 and found that they are a little too loose in the chock cartridge. I had to add a .030" spacer to get them to quit leaking. Looking at McMaster they have a 2mm(thickness) x 3mm (ID) o-ring that should be a perfect match for the stock o-rings. They are $7.63 for a bag of 50.
http://www.mcmaster.com/#5233t46/=ozpl5t
Chris
Chris
Hey guys just ordered by b4.2/centro combo on amain. Great deal by the way... Anyways old my tlr 22 2.0 I had for a week. Do the tlr wheels fit the B4.2?
I assume everyone heard about the combo? $325+ shipping after $25off code, get both b4.2 and centroc4.2 as one. That's almost $100 cheaper than separately.
What pinion do i need for 17.5 blinky? Med indoor carpet track
Well that all depends on track layout but a good baseline (at least for me) is start off with a 75 (76 if using stock avid triad slipper) spur and a 28 tooth pinion. I think its a great balance between speed and torque. I wouldnt recommend any spur smaller than 72 or a pinion larger than a 32 tooth. anything more will bog the motor too much and the performance will really lack. not to mention your motor temps will be astronomical. I used to run 69/33 but now i run 76/29 and its dramatically better. Youre gonna have to mess with gearing til you figure it out for your track but 75(76)/28 is where I would start.
Uhh? Puck system is much lighter combine that with avid triad slipper aluminum top shaft and aluminum pinion and titanium hinge pin and screw kit with a shortie lipo etc....
I held a c4.2 in my hands at the track yeserday and it felt alot heavier than my car, I was surprised at the difference, considering the only light weight mod im running is a shortie lipo.
One bite from the forbidden fruit is all it takes .....
4Likes
