Team Associated B4.2 Thread
People on here were saying centro is the AE European division, not a imitation. If the chassis hauls the mail like never before from what I'm seeing and reading then how is that a band aid? I'm buying one. Tomorrow hopefully!
If I'm being REALLY bad, and just want a quick fix for the day, then I'll pull out just the thrust assembly, and clean/replace. It'll make the diff much smoother.
When it comes to Diffs, you either build them properly or you don't, and with experience you get better at it. The biggest mistake I find people make is that they don't tighten their thrust down enough and therefore they get the bark which is vibration. If it can vibrate, things aren't torqued enough and some balls will have a bit more pressure on them and thus wear more quickly and unevenly than the rest and it's downhill from there. For my break-in I simply hold one wheel and throttle it lightly for about 30 seconds and then do the other side, then switch sides again and feather it a few times, then gun it for a bit, then do the same on the other side and it's done.
When the diff is built properly it can be felt immediately, and if it's wrong it's quite apparent as well. All I do is make sure my rings are indeed flat and I make sure they're free from ALL debris (even fine fibers can make for a rough diff) and use the proper lubes. My Diffs are ultra-smooth and they last forever that way and I only redo them if I have to tear down my Tranny for some reason. I've only ever had 2 diffs feel gritty and that was due to debris getting in. My current Diff has 6 months on it so it will be getting changed soon.
Those are encase, not enclosed. The balls reside on a disc washer so no more fumbling around with individual balls. Just slide the Avid ball assembly on and tighten down as you normally would. I'd venture to say the added bonus is the washer traps grease on the backside so the balls constantly pick up grease to remain lubed.
I would think the grooved washers are nice to help keep lube in also. I plan to try them on my next rebuild. I "THINK" the kits thrust balls are steel and not carbide. It does not seem to say anywhere, but based on the price of them, I am making that assumption. If I get the avid, I am torn between the ceramics and the tunston
Im thinking about a centro just because my home track is a carpet outdoor track. And rear motor is just terrible out there no matter what.
Not sold on mm on dirt as one of the guys I race with had a x factory car. My local indoor is too small for a mid motor to shine in corner speed because its alot of hairpins on this current layout.
Granted on a bigger track were you can carry alot more speed through the corners I think a mid motor would be awesome espically for stock!
Diff tips
No drill or sanding needed..
As you tighten down use less then 1 or 2 turns of the screw and roll the gear to break in the groove on the rings . As you tighten fewer turns and keep rolling gear to help push the balls into the ring to form the groove the balls ride inside .
When you reached bottom and think the diff is tight ?
use two drivers between the cups and torque the gear by hand .
If it the gear slips continue to tighten and roll the gear until you cannot move the gear by hand.
next
Install the gear into transmission ...
Switch car on and grip one wheel .
Give the car a small amount of throttle to spin the tire .
You don't need full speed , just part throttle is plenty .
After spinning each rear tire for a minute or two check the diff tightness.
It should of free up a bit and will need to be tighten some more.
tighten diff screw once again
then
break it in some more & check if the diff has not free up again .
if no change in the tightness ?
You are done ... enjoy
next
then
4Likes
