Like Tree5Likes
SC10 4x4 Thread
Old 09-24-2013 | 06:37 PM
  #35086
dirtbikekid33's Avatar
Originally Posted by cdlowe30907
Currently running 2 pad set up. Willing to upgrade to the VTS set up.
I'm planning on changing to the Tekin 4.5 motor in the future.
Yeah 2 pad is crap 3 is better but still crap go with the c-diff, slippers can't handle the power of 4 wd short course that's why every other brand went away from the slipper.
dirtbikekid33 is offline
Old 09-24-2013 | 06:57 PM
  #35087
fq06's Avatar
+1
fq06 is offline
Old 09-25-2013 | 09:21 AM
  #35088
Jordan Anderson's Avatar
You can't go wrong with the RC Shox center diff.
Jordan Anderson is offline
Old 09-25-2013 | 10:24 AM
  #35089
Shark413's Avatar
The RCShox cDiff is what brought me back to my SC10 4x4. I sold my Durango DESC410 and Losi SCTE and my Tekno SCT410 is now my back-up truck. Not saying these are bad trucks, because most of the top brands can win on a particular day. It's just that for me the ultra lite SC10 4x4 handles so well and more importantly it is so much fun to drive.
Durango DESC - Sold
Losi MIP - Sold
Tekno SCT410 - Back-up
Shark413 is offline
Old 09-25-2013 | 10:47 AM
  #35090
StPete40's Avatar
I'm putting mine on the track this Fall, after the monsoon ends here in Florida. Anyone have Exotek parts they want to get rid of? Front diff locker, chassis, rear hubs, etc.
StPete40 is offline
Old 09-25-2013 | 11:00 AM
  #35091
Cain's Avatar
Shark, your honest reviews of the products you have actually tried would make me pickup the sc10 4x4 if I had the conditions for it where it can benefit.
Unfortunately no indoor carpet running here this winter unless something changes
Cain is offline
Old 09-25-2013 | 12:22 PM
  #35092
Default diff oils
Just too many posts to go through themn all. Just need some good advice on what weight of oil to start with. 5000 all around, 7000F/5000R?
csilve is offline
Old 09-25-2013 | 12:58 PM
  #35093
Cain's Avatar
If you are using a slipper, go with 20K or so Front, and 5K rear.
If using a center diff, go with 10K - 7K front, and 5K Rear
Cain is offline
Old 09-25-2013 | 01:17 PM
  #35094
Wild Cherry's Avatar
30k front
7k rear
Wild Cherry is offline
Old 09-25-2013 | 01:20 PM
  #35095
Cain's Avatar
actually, maybe what we should ask first is what conditions do you run on?
Cain is offline
Old 09-25-2013 | 02:56 PM
  #35096
M03Racer's Avatar
I've been following this thread for a while now. I always like Associated since the golden tub buggy days. I race now and then at our local track and the 4wd SCT is very very popular, so popular in fact that they have to run two classes. I have an AE ProLite 4x4 but its not a serious race truck its good as a back up truck. I have a love and hate felling about the SC10 4x4. I didn't like the belt drive and the fact that AE stuck the motor in the rear of the chassis with very little air flow. But I actually drove one, a guy let me test his and man this truck was so dialed in that it was ridiculously good on the track. It ran so smooth and balanced on the track and so easy to drive its almost so predictable because you get so comfortable driving this truck. So I broke down and I got one. I will be running a Novak Havoc Pro ESC and a Novak 4.5T 550 motor. I saw that Novak recommends a 12T pinion with this set up. Now my question is what else can I do to the truck to make it better for racing. I will be racing on a fairly technical course. They race 1/8 and 1/5 on this track. Its dirt not clay. What tires would you guys recommend I have some AKA gridiron, cityblocks and Duratrax Lineup, Lockup, and shotgun I had these for 2wd SCT's.
M03Racer is offline
Old 09-25-2013 | 06:02 PM
  #35097
What motor/esc combos everyone running?
I run on medium outdoor clay track with tire of choice being Holeshots.
Like I said earlier, I'm running the Castle SCT system.
What would be the budget slipper setup to use for now? I have about $20 to spend right now. I'm seeing the VTS slipper on Ebay for about $15
What diff fluids are suggested for my setup ? I need to do some maintenance.
cdlowe30907 is offline
Old 09-25-2013 | 07:26 PM
  #35098
TommyJoe's Avatar
I'm running the tenshock sc401 4400kv with a HobbyKing 120 amp esc, 12t pinion and 62t spur. I race on a big 1/8 scale outdoor track w/medium grip. I run holeshots as well. My factory team kit came with the 3 pad slipper, so I don't have any experience with the old diff. I tried the exotek front locker, played with the diff fluids and front clicker, switched between the 19 and 20 tooth pulleys, all of which helped a little bit. About two months ago I had the money so I decided to order the c-diff. Damn. In terms of return on investment, it beats the exotek chassis, saddle pack configuration, and 16mm shocks all day long. If you stick with the pads, I'd try 20k front/7k rear in the diffs. Otherwise, save your money for a few weeks and invest in a c-diff.
TommyJoe is offline
Old 09-25-2013 | 09:39 PM
  #35099
My PINK is packN the Reedy 4.5 Sonic , backed up with a Lrp FlOW ESC
Both run cool & smooth ...
Controlling the power with the VTS slipper , well know to be the best performer on the track ...
Tip
Using a additional slipper pad for
improved acceleration & traction ...
Old 09-26-2013 | 06:07 AM
  #35100
Tip
Cherry did you try mounting the shorty Side ways to the front. Brings more weight upfront so you can remove Some weights next to the servo and lighters is better right?
Tomas15 is offline
