Team Associated B4.2 Thread >
Like Tree4Likes
Old 09-24-2013 | 08:21 AM
  #9661
Grasschopper's Avatar
Originally Posted by turbo2cam
So can you get to the C-hub location with the exotek hubs now? I thought Yaiba hubs were the only ones that you could achieve both locations with? (heard you had to shave down the exotek hubs for c-hub locations?)
Right, that's how I read it, says they are Version 2 of the rear hub design.
Grasschopper is offline
Old 09-24-2013 | 08:32 AM
  #9662
Wildcat1971's Avatar
Tech Prophet
yeah, you can get to the c hub height. My only issue is that I dislike alum ball mounts. Even with Ti studs, you will break a stud off in those hubs if you crash hard enough. you want the stud to be long enough that is hangs out the bottom a little, but does not rub the cva obviously. So that is a stud breaks, you can pull it out the bottom.
Wildcat1971 is offline
Old 09-24-2013 | 08:41 AM
  #9663
Flip boy's Avatar
Angry
+1 I have seen a few guys throw away there 40.00 hubs after breaking a ball stud off and failing to sucessfully drill and tap the hole.
Flip boy is offline
  #9664
Wild Cherry's Avatar
Originally Posted by rc car guy
Hey guys sorry to stray topics, but i was wondering about the chassis stiffeners that vision rc makes. I made some similar ones that are 60g. How much do the vision ones weigh, and what happened when you used them. What is the advantage of using them? I race indoor on ozite high bite carpet, and have a b4.2. 17.5 blinky
Will have the Vision stiffener's & their new precision shock bushings soon .
Will let everyone know how they both perform for me ...
Wild Cherry is offline
Old 09-24-2013 | 09:26 AM
  #9665
turbo2cam's Avatar
Might be a good idea to slot the bottom of the ballstud before installing them, so you could use a flathead to remove the broken bottom half. Then again, if you are running the very outside hole, not sure how you would get to the bottom of the stud because the hinge pin is in the way. Hmmm...
I like the vertical stud mounting for sure. I've been having problems with my stud/nuts coming loose on my AVID towers lately, and not sure if it's a problem with the studs/nuts or the towers flexing too much. But, not so sure I want to jump on the current offerings of vertical stud hubs.
turbo2cam is offline
Old 09-24-2013 | 09:30 AM
  #9666
Tech Prophet
mine were coming loose too. I replaced them with a full sized 4-40 steel nut and put lock tite on. been good for a couple months now.
Old 09-24-2013 | 10:43 AM
  #9667
lodhammerdin's Avatar
Anytime I put vertical ball studs in, I use my dremel and cut a nice sized nitch in the botom on the threads so that in the event I break a ballstud, I can use a flat tip to pull the remaining piece out.
lodhammerdin is offline
Old 09-24-2013 | 10:46 AM
  #9668
I always do that, I jusg posted the same thing before I saw your post.
Old 09-24-2013 | 10:55 AM
  #9669
Wouldn't just be easier to just stick with the Ae hub and never have to worry bout stripped ball stud's ruining a $$$ rear hub ?
Old 09-24-2013 | 11:02 AM
  #9670
skrichter's Avatar
I was going to purchase the Yaiba hub, until I saw this new Exotek hub in the thread.
I was going to consider running the .40 long TiNi ballstud, but it doesn't have the short neck (so it would be essentially like running A hub). http://www.amainhobbies.com/product_...all-Stud-Set-2
I'll have to stick with the stock black stud for C Hub height.
skrichter is offline
Old 09-24-2013 | 11:09 AM
  #9671
skrichter's Avatar
Default Tungsten
Has anyone tried the new Avid Tungsten thrust bearing?
I was considering getting the TLR tungsten diff balls to go with it.
Old 09-24-2013 | 11:32 AM
  #9672
turbo2cam's Avatar
Or stick with the AE stuff and worry about the ball studs coming loose on the carbon towers...
Both setups have their drawbacks....
Old 09-24-2013 | 11:38 AM
  #9673
Autocratic's Avatar
For those with the Yaiba or Exotek hubs, how are the bearing tolerances? One thing I can't stand with the AE hub is how loose the bearings are. Getting a little tired of taping the outer and thread locking the inner just to keep them from moving around.
Autocratic is offline
Old 09-24-2013 | 11:45 AM
  #9674
Who me worry ?
Not ......
Have fun grinding that slot and ruining the threads on the stud ..
Maybe the stud will not cross thread for you when installing or maybe not..
Your $$$....
Old 09-24-2013 | 11:47 AM
  #9675
I just installed the Yaiba and the bearing tolerances are AMAZINGLY perfect. You couldn't get the fit to be any tighter and have the bearings go in but at the same time there is no play. With that you would need near perfect alignment of the bearings and they have that too.
The Yaiba are a very high quality product...my only beef with them is that I wish they were tapped for a hinge pin set screw and I hate the red ano with the other parts on the car being blue. I'm not buying all of the Yaiba parts to have matching red.
