Team Associated B4.2 Thread
#9632
I thought of the same thing but I measured my car against someone elses with the stock tower and theres not a measurable difference so I left my limiters the same.
#9633
Mine was free. While I was in Afghanistan, I met a guy who's related to the lead engineer at psm. They sent me 5 for free, was very greatful and appreciative for that.
#9634
Anyone have a good suggestion for a nice turnbuckle wrench? I bought this one, and it sucks. Doesn't fit the turnbuckles (too small), and the damn thing is like half the size of my pinky.
http://www.amainhobbies.com/product_...kle-Wrench-3mm
#9635
#9636
I use the Hudy with a bunch of sizes but used this one the other day and felt good.
http://www.amainhobbies.com/product_...nbuckle-Wrench
#9637
#9638
Hideeho
I have some vp-pro's (same as the huddy's) & the AE one linked above, I have used lunsford & a couple of others. I hate all of them. I currently use small craftsman wrenches :/. What I would really like to find is something like the losi wrench, but longer, larger diameter, & knurled rather than flat sided. Single sided would be fine, but double sided would be better. If anyone knows who makes one like that, Please let me know.
#9641
Hideeho
#9642
LOL I use the stock plastic one that comes with the car. I have the Losi and use it on my other cars but don't like it as the 3.5mm is down inside the 5mm. It's ok in some locations but not for the rear camber links. I should get something else...great time for another Amain order...the last one hasn't even arrived yet.
#9643
Hey guys! Need some setup help. I'm new to the site but I've been lurking for a while, I've read most of the thread. So I'm currently running my b4.2 at SDRC, first time there was yesterday. Current setup is:
Front: Bar Codes, Green Springs, 32.5 AE oil, 3x1.4 pistons, -1 camber, no weight
Rear: Bar Codes, Green Springs, 30 AE oil, 3x1.4 pistons, shaved brace/C Hub, -1 camber, 10 grams in each rear pocket
Currently got a 10.5 in it but will be running a 17.5. So the car is sliding/spinning out on power around corners, its got plenty of steering. Overall it's not bad, driveable but I would like some more rear side traction. Forward bite is good, can clear the jumps smoothly. Thinking of changing the front to 35 weight or lowering the rear oil to 27.5. Any other suggestions? Thanks!
#9645
17.5 Running on a small track 69/34 is a good starting point
4Likes
