Team Associated B4.2 Thread >
Like Tree4Likes
Old 08-27-2013 | 10:30 AM
  #8806
thecman26's Avatar
Originally Posted by theblitzkidd
True, they are a pain to clean lol
yeah, I have a few sets of the pins rims, and they are all the reflux style!
I used to run them and loved them! I sold them when I sold my D4...
thecman26 is offline
Old 08-27-2013 | 10:31 AM
  #8807
thecman26's Avatar
Originally Posted by Waflet
Hideeho
Thats the JC Rulux wheels. I LOVE those wheels & ran them until I converted to hexes. Every few weeks I'll get on the JC thread here & pester Paul to make rulux with hexes. Maybe if a few more folks jump over there & ask for them we will get them eventually.
here's the thread...
http://www.rctech.net/forum/electric...hread-429.html
Ok, I can do that!
Old 08-27-2013 | 10:34 AM
  #8808
Wildcat1971's Avatar
Tech Prophet
well "technically" the air can pass through the spoked wheels and reduce side bite on the track and in the air. That was the exact claim as to why people like the dished SC wheels.
Wildcat1971 is offline
Old 08-27-2013 | 10:36 AM
  #8809
I still run mine, I have a ton of wheels with the pins so I keep the pins on the buggy, and as far as the air passing thru idk if that's a good or a bad thing, I don't really notice!!
theblitzkidd is offline
Old 08-27-2013 | 10:41 AM
  #8810
Waflet's Avatar
Hideeho
If your 1st name is Ryan, you MIGHT be able to actually tell the difference & even then I don't expect it would make any difference in actual lap times.
Waflet is offline
Old 08-27-2013 | 10:42 AM
  #8811
thecman26's Avatar
I always thought the Rulux wheels looked fast, and thats what counts!
  #8812
Tech Prophet
dup
Old 08-27-2013 | 10:43 AM
  #8813
Tech Prophet
heya, My name is "Ryan" sweet. And i can definitely feel the difference, I lose like 2 laps and if they are black spokes, I lose like 4 laps.
Old 08-27-2013 | 10:44 AM
  #8814
Tech Prophet
you need chrome ones with spinners.
  #8815
Well there is a dif between looking fast, and accualy being fast
Old 08-27-2013 | 10:46 AM
  #8816
the incubus's Avatar
Originally Posted by Grasschopper
Ok so no D3...other than the Viper which I pretty much know I won't be using (son may actually want to race) so I will be buying. The SP is interesting...do you have a photo of it from the end with the motor connectors? Do they stick out very far? I would be worried about that a little bit as opposed to a more standard setup.
Not one bit. They really did a bang up job with their stuff this time around. Referencing the images below, the motor leads stick out about 3/16" and that's it. They also slide in rather firmly and don't slide out very easily which is a major plus.
You solder your motor leads right onto the female bullet receiver connectors and the motor itself has the Bullets they slide into. I'll try and snap a pic of mine for you, though I was certain I had but I can't find them ATM.
This picture shows how neat and tidy the end bell is:
I just wish they could revise it so all the connections reside right next to one another.
Here it is with leads all soldered up:
the incubus is offline
  #8817
thecman26's Avatar
Its a mind trick, if you think your fast you will be fast!
Old 08-27-2013 | 10:47 AM
  #8818
Cain's Avatar
I have this motor. the connectors don't stick out far at all. Its kind of nice to just unplug and change.
The motor is smooth for sure, if you need torque though you will want the 12.5mm rotor they sell, one of which is like getting unobtanium at times ... I had to hunt it down myself.
The sensor boards ... I would suggest if you have an ESC that can do timing, SIMULATE the timing on the motor using it to get an idea what kind of board you would want. The Green Board and Yellow Boards are pretty common though.
Cain is offline
Old 08-27-2013 | 10:51 AM
  #8819
Grasschopper's Avatar
Ok so the stock photo shows the motor with the bullets inserted. I was worried you connected something additional to what was hanging out the back just showing in that photo.
I assume the motor comes with a set of the bullets...right?
Well my ESC can do timing but this is for 17.5 blinky so per rules that is a no no...as I assume changing rotors and sensor boards would be. Is that assumption correct?
Grasschopper is offline
Old 08-27-2013 | 10:52 AM
  #8820
Hahahaha well I will try that, cause if that's the case I can be reallll fast hahahaha
