Team Associated B4.2 Thread >
Like Tree4Likes
Old 09-20-2013 | 10:10 AM
  #9556
Big Will's Avatar
Originally Posted by Wildcat1971
now that I am thinking about it. How did you assemble your cva's? set screw and the clip? some people had some issues doing both and it caused a noise and a slight binding I think.
Just the clip.
Big Will is offline
  #9557
Big Will's Avatar
I will take it apart again and check everything.
Big Will is offline
Old 09-20-2013 | 10:12 AM
  #9558
Wild Cherry's Avatar
Tech Legend
Recommend using both the grub & clip ..
Clip can come loose easy , CVA also rubs arm on hard landings and zip there goes the clip ...
New test
I am going to try the car with a MIP CVD instead of the Ae CVA .
Heard you can find extra steering with the CVD ,
less binding using the CVD..
Wild Cherry is offline
Old 09-20-2013 | 10:40 AM
  #9559
aeRayls's Avatar
New test
That's the opposite with cvd's
More forward bite on throttle... Only truly noticeable when you punch it coming on to straights.
aeRayls is offline
Old 09-20-2013 | 10:49 AM
  #9560
BRSracing's Avatar
Which kit servo horn goes with Spektrum servos??? I have found where the servo is 23t, however I can find no information on how many splines each horn has. Anyone know where I can find the splines of the kit horns?
BRSracing is offline
Old 09-20-2013 | 10:52 AM
  #9561
Wildcat1971's Avatar
F=25
H=24
A=23
J= 23 also? unsure
Wildcat1971 is offline
Old 09-20-2013 | 12:24 PM
  #9562
Savox has the same tooth count as Futaba. In the kit manual it references the Futaba Horn as Horn F. Use that one. 25 tooth.
chevmaro is offline
Old 09-20-2013 | 12:42 PM
  #9563
DanielC.'s Avatar
Spektrum is JR horn. Savox makes several of the spektrum servos but with 23t horn.
DanielC. is offline
Old 09-20-2013 | 01:32 PM
  #9564
F18engineguy's Avatar
Originally Posted by Big Will
Just the clip.
Agreed. There is a chance of binding using both. Follow the book
F18engineguy is offline
Old 09-20-2013 | 01:39 PM
  #9565
I would take it a part and look for anything a miss. The put it back together, put the wheels on with no pinion attached. put the car on a stand and spin both wheels at the same time in the same direction and see if it does it. Also, compress the suspension a little to get the bones level and give it a good spin. I say bones level, because that should eliminate and cva bind/rubbing.
Old 09-20-2013 | 02:04 PM
  #9566
racer1812's Avatar
Super Moderator
How you know dat? JR made/makes all the cheaper Spektrum servos. I would think the higher quality stuff would come from them as well. Not saying your wrong....
racer1812 is offline
Old 09-20-2013 | 02:34 PM
  #9567
DanielC.'s Avatar
The spektrum 6040 I believe is a 1258 with a 23t spline, and their shorty servo (6070?) is a 1251. I don't think savox OEM's their higher end servos like the 9100.
DanielC. is offline
Old 09-20-2013 | 04:44 PM
  #9568
King DORK's Avatar
I don't work at the facility that makes them, but I'd have to disagree. Besides having the same specs, if they were truly the "same servo" just with a different spline, the 6040 would be much louder and almost always require a cap or external bec like the 1258. I rarely hear of a 6040 causing any glitching or brown out issues. The 3 6040 servos that I run are very quiet and have never given me a single issue, and that's running with a Spektrum radio and used to run a MMP esc (with no issues). Not saying I feel the 1258 is crap. I'm just not convinced that they're the same servo.
King DORK is offline
Old 09-20-2013 | 04:58 PM
  #9569
Waflet's Avatar
Hideeho
If your running a dsm2 receiver with the mmp & a 1258 you don't need a cap either. That's what I run. If you set your end points properly & have no bind in the steering a savox is only marginally louder than anything else. 6040=1258
Waflet is offline
Old 09-20-2013 | 05:19 PM
  #9570
My 6040 is definitely quieter than either of my 1258's. IMO not the same servo.
ntJeff is offline
