Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-22-2013 | 07:39 PM
  #8731
Hoese37's Avatar
Originally Posted by Cain
question on shimming of the center diff. my EB48 has the variety of shims between the outdrive cup and the bearing as shown in the older manual, but the spider gears don't have the shims.
What determines if it needs to have the shims between the outdrive cup and bearing on the center diff? I want to know if I can remove these.
Not sure I follow...
Hoese37 is offline
Old 08-22-2013 | 07:57 PM
  #8732
Cain's Avatar
Bag A in the manual shows TKR5112 then a bunch of shims, then a bearing before going on to the spur gear. At least, that is what my printed manual shows.
Online, the current manual doesn't show this. I am wondering what changed on the vehicle so you don't have to use these shims. From that info, I can determine if I can remove the shims.
Cain is offline
Old 08-22-2013 | 08:21 PM
  #8733
teknorc's Avatar
The motor mount was changed in October last year to take up the slack.
teknorc is offline
Old 08-22-2013 | 08:42 PM
  #8734
Rockthecatbox21's Avatar
With all due respect, that was the one thing i would have liked to have seen on the eb48.2. I feel a new beefier motor mount would be a great idea and would greatly benefit the et48 as well. I would definitely order a new XT motor mount if it was available. Only problem with the stock mount is it develops a little bending on the lower lip of the mount. The only two things needed to make this kit as great as i can be are a new motor mount and maybe a spring steel driveshaft.
Rockthecatbox21 is offline
Old 08-22-2013 | 08:48 PM
  #8735
Cain's Avatar
Is there a way I can tell by looking at the mount if its the new one or old one?
Cain is offline
Old 08-22-2013 | 10:16 PM
  #8736
Bob-Stormer's Avatar
Originally Posted by Kuya_Kimo
Did stormer have some in stock and I missed it? If so... Dang.
Looks like we got a few more today.
http://www.stormerhobbies.com/cgi-bi...=ns&pn=TKR5002
Bob-Stormer is offline
Old 08-23-2013 | 03:09 AM
  #8737
I thought they looked the same. I couldn't tell the difference but i wasn't really looking. You could always depth mic the bore or just dry fit everything and see if you can get the shims in. The bore should be about .6mm or .023 (ref) shallow if it's the new compared to the old. I could see it if i looked (that's what i do for a living) average person, probably not
Dont Hack Me is offline
Old 08-23-2013 | 03:51 AM
  #8738
Graham11's Avatar
You guys offer great prices, just need to get you more inventory seems like everything I want flys off the shelves by the time I pull my CC out.
On another note, because the EB48.2 pictures reminded me, does Tekno have a deal with Tekin? The original EB pics had the mamba monster but now all Tekno kits have Tekin systems?
Graham11 is offline
Old 08-23-2013 | 06:37 AM
  #8739
Hoese37's Avatar
Just gotta put the best electronics in the best vehicles!
Hoese37 is offline
Old 08-23-2013 | 07:51 AM
  #8740
Graham11's Avatar
Agreed as you can see below ha.
Anyone looking for a new EB48 original for cheap?
Graham11 is offline
Old 08-23-2013 | 08:01 AM
  #8741
Hoese37's Avatar
Whats cheap?
Hoese37 is offline
Old 08-23-2013 | 08:25 AM
  #8742
Maddog94's Avatar
Can anyone say the purpose (benefit) of the HD Servo Saver Spring?
I have had what seems to be an intermittent centering problem, where I find that I need to adjust my steering trim from time to time. I have isolated it as to NOT be the servo itself. Everything seems free of binding. Wondering if it just needs a stronger spring or perhaps crank down on the existing spring a little more.
Maddog94 is offline
Old 08-23-2013 | 09:12 AM
  #8743
Hoese37's Avatar
That does sound like is skipping a tooth or two inside the servo. The spring should align the cam in the saver easily. Pull the steering post out and check to make sure the cam halves rotate freely and that they are clean and smooth.
Hoese37 is offline
Old 08-23-2013 | 09:56 AM
  #8744
Cain's Avatar
thanks for the info. So is it the metal part or the plastic one that changed? If its the plastic one, may just order it then.
Cain is offline
Old 08-23-2013 | 10:12 AM
  #8745
bcjoldbq's Avatar
http://www.teknorc.com/tekno5/wp-con...6/TKR6008s.jpg
I have a first release EB48.
Just picked up (2) new TKR6008 for a shock rebuild and noticed that there is a new group of two molded pieces on the tree.
The parts are:
---- upper shock bushing (2)
---- internal o-ring spacer (2)
---- shock piston (2)
---- bottom piece of cartridge assembly (longer, redesigned)
---- UNKNOWN (2)
Unless the questioned pieces are an updated upper shock mount bushing, I'd like to know what the piece is.
Note: the URL above is the 'old' TKR6008.
bcjoldbq is offline
