Like Tree5Likes
SC10 4x4 Thread
Old 08-19-2013 | 07:33 PM
  #34846
Originally Posted by Cain
Got it, sorry pulled a 60+ hr work week. I will see about converting the file to something that can be uploaded tomorrow with adobe pro.
It ok I know how those 60 hour weeks go. I just don't know enough abut that stuff to belive it or not I just learned how to send it as an attachment in the email like 3 weeks ago and boy was that fun
imrob is offline
Old 08-20-2013 | 05:58 AM
  #34847
MD's Avatar
MD
Originally Posted by imrob
I think the havco pro will fit just fine it what I have but you will have to take off the fan I think. I did not put mine to sale pack yet. I got the crap for it just did not have the time to make it there
Thanks.
MD is offline
Old 08-20-2013 | 05:59 AM
  #34848
MD's Avatar
MD
Originally Posted by boborc
The havoc pro will fit under the belt cover with fan if you change the 4-40 socket cap screws to button head screws that hold the fan on. I think they are 5/8 inch long but I could be wrong. Most 1/10 esc will fit under the belt its the 1/8 stuff that you have to move things around or get out the dremel and chop
Thanks.
MD is offline
Old 08-20-2013 | 07:26 AM
  #34849
TomErickson's Avatar
I have the HAvoc Pro SC in my SC10 4x4 with the original fan and screws. If you are running the saddles or other packs that allow you to install the ESC on the spur gear side of the chassis you will have to position the fan offset ont he cooling fins so that it clears the belt tunnel. That's it really.
TomErickson is offline
Old 08-20-2013 | 07:33 AM
  #34850
MD's Avatar
MD
Thanks.
MD is offline
Old 08-21-2013 | 02:45 PM
  #34851
I decided to go ultra light on this one.. will be running a shorty lipo up in front... anyone here
Who has tried that setup... anyway i just shaved of about 100 grams cant be wrong..
sundance_kid76 is offline
Old 08-21-2013 | 04:50 PM
  #34852
smc shortys work great
slashmaxx242 is offline
Old 08-23-2013 | 05:21 PM
  #34853
oddism's Avatar
Hi guys. Recently purchased an SC10 4x4 FT and I'm looking at stocking up on spares. What are the most common parts that need replacing from wear/breaking.
Also, where can I look at video of an sc10 4x4 being put together? I want to watch and learn how it's done in case I need to strip mine down. My mechanical knowledge is really limited and I find it easier to learn by watching. Cheers
oddism is offline
Old 08-23-2013 | 09:09 PM
  #34854
Originally Posted by M03Racer
Is there a new SC10 4x4 on the horizon or no. I really like this truck but I'm not a fan of the cramped motor and belt drive. I have a modified AE pro lite 4x4 I like the shaft drive in this truck. But I'm still wanting a second 4wd SCT for a back up or main racer and I'm more of a AE fan then Losi and would be game for a re-designed SC10 4X4.
I seriously doubt there will be anything more than a .1 or.2 version coming out anytime soon.
quick5pnt0 is offline
Old 08-23-2013 | 09:19 PM
  #34855
dirtbikekid33's Avatar
Well the best way for me is just take it apart yourself memorize how it goes together and you will get faster and learn tricks, just be sure you have a manual if you get lost.
dirtbikekid33 is offline
Old 08-23-2013 | 10:23 PM
  #34856
have all fluids at your disposal when rebuilding or regular maintenance
banditstpk is offline
Old 08-23-2013 | 10:43 PM
  #34857
Originally Posted by dirtbikekid33
Could always get a tekno then.
+1
But srsly: What Cain said.
SC Shaun is offline
Old 08-24-2013 | 07:18 AM
  #34858
Cain's Avatar
Hey cain did you ever get that email set up sheet I sent u last night or the other day I don't know what state you are in. I just can't figure out how to get it up on this either the right way. I can't get it to go as an attachment and if i copy and past it Get all messed up.
won't convert (sorry for the delay). So I am going to just type it here:
FRONT:
- Steering Rack: Option, BACK
- Washers: 0
- Bump Steer Washers: 0
- Outer Position on A-Arm
- Steering Stop Gap : 0
- Anti-Roll bar: 1.8
- Body Mount: 2
- Camber: -1
- Toe: -1
- Ride Height: Bones Level
- Shock Position On tower: 2
- Washers On Tower: 3mm
- Ballstud Position on Tower: Inner
- Front Pulley: 20T
- Tensioner Position : 3
- Full Time 4x4
- Shocks Spring: Blue
- Shock Piston: #2
- Shock Oil : 27.5 AE
- Shock Limiter: NONE
- Shock Rebound: Zero / dead shocks
- BLADDER
REAR:
- Wheelbase: Medium
- Hub: C Position
- Anti-Roll bar: NONE
- Body Mount: 2
- Camber: -1
- Toe: 3/2
- Shock Position On tower: 1
- Washers On Tower: 1mm
- Front Pulley: 20T
- Shocks Spring: Red
- Shock Piston: #2
- Shock Oil : 22 AE
- BLADDER
Electronics:
- 4.5 Novak Ballistic 550
- 12T / 62T
- Stick Battery In middle
Differentials
- DIff Front: 7K
- Diff Rear: 5K
- Quad Slipper
Cain is offline
Old 08-24-2013 | 11:16 AM
  #34859
FRONT:
- Washers: 0
- Body Mount: 2
- Camber: -1
- Toe: -1
- Front Pulley: 20T
- Full Time 4x4
- Shock Piston: #2
- BLADDER
REAR:
- Wheelbase: Medium
- Hub: C Position
- Body Mount: 2
- Camber: -1
- Toe: 3/2
- Front Pulley: 20T
- Shock Piston: #2
- Shock Oil : 22 AE
- BLADDER
Electronics:
- 12T / 62T
Differentials
- DIff Front: 7K
- Diff Rear: 5K
- Quad Slipper
Thanks for the try I . this is for s loose blown out track
imrob is offline
Old 08-24-2013 | 04:21 PM
  #34860
Hey guys this is my first post on here.This is my current setup however my track just did a complete rebuild so im sure it will change.
Electronics
-mamba max pro esc
-Novak ballistic 4.5 w/heat sink and milled motor pate.+16 degrees timing.0% drage brake
-savox 1258tg
-spektum DX3S and sr301 receiver.
Suspension
-Bypass1 pistons
-yellow front springs/red rear
-yellow front sway bar/orange rear
-emulsion style
-all 4 on the middle hole/all outside on the arms
-32.5 front fluid/40 rear
-exotek rear hubs 6mm on hub stud/5mm inner stud
-rpm arms all around
-ride height 25mm front/26mm rear
- -2 camber all around
- +2 toe
Drive train
-60k in the front/5k in the rear
-Exotek locked front
-20t rear/19t front
-VTS slipper
-12t pinion
-aluminium pulleys
Battery
Trakpower 6000mah 80c 2s
Tires
Proline suburbs super softs w/aka +3mm offset wheels
Body
Proline tundra
Future upgrades
-boca bearing set
-possibly center ball diff
-4 postal scales and a 55/45 balance.I know this truck could use the weight.
-makita electric drill lol
This setup pulls like hell and great in turns.When i add the weight i will make the ride height considerably higher.I'll add a pic as soon as i find out how to.
AEmike50 is offline
