Team Associated B4.2 Thread >
Like Tree4Likes
Old 07-25-2013 | 06:29 PM
  #7291
http://www.liverc.com/photos/albums/...t/DSC_0660/lg/
This seemed to be the only picture I could find of any of the Centro conversion kits that some of the AE drivers were using. Are they testing 4.1 or 4.2 kits? the gearbox is from the 4.1...
JiuHaWong is offline
Old 07-25-2013 | 06:37 PM
  #7292
Jmuck69's Avatar
Originally Posted by F18engineguy
What ball cups are those? I see a lot Olof guys with those. They look gray
Standard AE cups. It's the way the light hits it.
Jmuck69 is offline
Old 07-25-2013 | 06:39 PM
  #7293
rcman182006's Avatar
All ready for my first race in ages, let't hope it stays together lol (it's a 4.1WC)
also good gearing starting point for blinky 17.5 in case we have a class of them? (Tekin RS Pro and Trinity RevTech motor if that helps)
rcman182006 is offline
Old 07-25-2013 | 06:41 PM
  #7294
Jmuck69's Avatar
Cav's C4.1.
Jmuck69 is offline
Old 07-25-2013 | 06:49 PM
  #7295
BLKXJ96's Avatar
Looks cool! Everything is so compact with the speeder in front of the batteries, That pic also gives a good idea of the Chassis. The rear shock tower looks just like a B44 tower.
BLKXJ96 is offline
Old 07-25-2013 | 07:42 PM
  #7296
the incubus's Avatar
Gearing is dependent on the track. Having said that a good starting point for stock would be 78-80 spur with a 28-30 pinion. Should give you good low end torque and decent top end. If you find you need more top speed simply lower pinion size. I drop 2 at a time as 1 doesn't really allow you to see and feel enough of a difference.
the incubus is offline
Old 07-25-2013 | 07:56 PM
  #7297
Skillz_B's Avatar
Hard to say, but they look like AE or Jconcepts http://www.amainhobbies.com/product_...-Cups-Black-20
Skillz_B is offline
Old 07-25-2013 | 08:03 PM
  #7298
3srcracing's Avatar
What was I thinking??
Time to change it up a little bit.
vvvvvv
3srcracing is offline
Old 07-25-2013 | 08:32 PM
  #7299
STLNLST's Avatar
Originally Posted by bds81175
I've got Exotek's and mine don't bind with hexes. Why would a hub cause binding with one method of tire mount vs. the other? They both put the force through the bearing races and the crush tube to the axle. Weird...
4 pairs and all 4 with the same issue. Weird is right
STLNLST is offline
Old 07-25-2013 | 08:42 PM
  #7300
Hey aeRaylis, Nice quote!
DG Designs is offline
Old 07-25-2013 | 09:06 PM
  #7301
ChrisAttebery's Avatar
32/72 is a great place to start for 17.5NR.
ChrisAttebery is offline
Old 07-25-2013 | 10:41 PM
  #7302
aeRayls's Avatar
Ha... Yessir
aeRayls is offline
Old 07-25-2013 | 11:10 PM
  #7303
wild gopher's Avatar
i'm guessing both of you have skied the K12?
wild gopher is offline
Old 07-25-2013 | 11:14 PM
  #7304
Wild Cherry's Avatar
Tried using nothing for a bleed seal but oil would seep out , dust collect & made a mess ...
Wild Cherry is offline
Old 07-25-2013 | 11:16 PM
  #7305
aeRayls's Avatar
You bet... On one ski too
AND I actually do drive a black camaro!
aeRayls is offline
