Like Tree5Likes
SC10 4x4 Thread
Old 07-24-2013 | 12:16 PM
  #34621
MantisWorx's Avatar
Originally Posted by Jstall7543
I wouldn't use 3.5mm bullets unless they were castle brand. I've seen alot of motor problems on my buddys rigs because he insists on running cheap bullets because he's to lazy to do his own soldering. He always runs the cheap bullets and they just dont last and his motors cut out all the time but he still runs them.
+1 DO NOT USE BIRDCAGE BULLETS, THEY CAUSE NOTHING BUT PROBLEMS
MantisWorx is offline
Old 07-25-2013 | 04:02 AM
  #34622
boborc's Avatar
That's where I was starting to lean. Shows up on Hi draw applications. What do you suggest?? I like the idea of being able to switch things with out soldering all the time, especially trackside its quicker and at one track I have no a/c power.
boborc is offline
Old 07-25-2013 | 06:48 AM
  #34623
MantisWorx's Avatar
Nothing wrong with bullet style connections its just that the birdcage style SUCK! TQ makes some nice ones as well as many others.
Old 07-25-2013 | 06:54 AM
  #34624
I had the same issue where connectors would DE solder during racing 4wd class. Soon as I changed the bullets to NON birdcage style issues immediately was resolved 100%.
mconway is offline
Old 07-25-2013 | 11:45 AM
  #34625
Default SC10 4x4 with Exotek - Setup help
I have been searching for a starting SC10 setup with folks using the Exotek chassis. With all the weight added, I'm assuming Springs, Oil weight, etc might want to start differently. I mainly run Med-Large outdoor tracks, med grip, hard pack dirt and often dusty conditions.
Thank you in advance for the help getting me in the right direction.
mconway is offline
Old 07-25-2013 | 01:11 PM
  #34626
Cain's Avatar
shoot me a pm with your email, I have something you could try and see how it goes for you.
As for the discussion on bullets, when I was wanting to swap motors, I used castles 6.5mm bullets at the time. Excellent connections.
Cain is offline
Old 07-25-2013 | 03:49 PM
  #34627
I there supposed to be any play in the steering?
banditstpk is offline
Old 07-26-2013 | 08:53 PM
  #34628
TomErickson's Avatar
I got a chance to test my light SC10 on an 8th scale track. I used the stock blue springs, RCshox c-Diff V2 and 2-stage pistons with 5k in both diffs. The truck was significantly better than ever. I had posted that I had some sort of driveline issue but I checked everything and it was fine. Love this truck now. I'm racing it tomorrow!
TomErickson is offline
Old 07-28-2013 | 06:18 AM
  #34629
I picked up a M2C toe block last night and it did not come with a chart for the toe block settings, so I was hoping that someone here had a PDF, picture, or a link to the chart...
thanks
BenG477 is offline
Old 07-28-2013 | 01:31 PM
  #34630
Does anyone put a little black grease on the VTS trust bearing
rippen is offline
Old 07-28-2013 | 02:10 PM
  #34631
GraphiteChassis's Avatar
I did once... it ruins the inside pad. Black grease all over it.
GraphiteChassis is offline
Old 07-28-2013 | 03:06 PM
  #34632
I just rebuilt both diffs and I noticed that the thrust bearing was dry so I thought I would ask
rippen is offline
Old 07-28-2013 | 03:39 PM
  #34633
MarqueeRc's Avatar
I have done it, and works just fine for me. The key is to use a very minimal amount. I dab a dot on my finger and rub it up against the thrust bearing balls. Its like a thin film rubbed equally throughout the bearing, so that there is no clunky chunks of grease hanging around. Have been on the same thrust bearing for almost 2 years now. Think the manual even says to use a small amount on it. I just use a minimal amount so no excess grease gets flung around. Keeps it smooth and quiet imo.
On the other hand, i don't think its absolutely necessary, as that thrust bearing should last a while regardless.
MarqueeRc is offline
Old 07-28-2013 | 03:54 PM
  #34634
That's what I was thinking, just a small dab just to coat it.
rippen is offline
Old 07-28-2013 | 04:22 PM
  #34635
hey rippen, I see you are using the same hobbywing setup I just put in my sc10 4x4 and im wondering what gearing you are using and what settings on your esc? how do you like it? thanx
mikeinsocal is offline
