Team Associated B4.2 Thread
#5761
http://www.amainhobbies.com/product_...nsert-Medium-2
How many sets of tires can I get out of these inserts before I have to replace them?
Do I punch holes in only rear tires?
(I will stuff 3/4 of a rear foam in the front tires)
Do I punch holes in the front tires?
What size holes?
Thanks!
What size holes?
Thanks!
If you cant get those i would recommend the AKA stuff. If you use closed cell foam you will want to punch two 2-3mm holes in the tire (180° from each other). If you use standard foam then you only need the hole in the rim. Depending on the surface and how much you run the foams can easily last a couple sets of tires.
#5762
What size holes?
Thanks!
What size holes?
Thanks!
#5763
#5764
#5767
#5769
You are going to want these:
I thought racers prefer the 3206-2 better in the rear tires?
What is 2-3mm equal to in inches of the punching tool?
#5770
I dont know...i use the one in the middle...maybe just smaller than the middle one. The 3206-3 has a rounder profile and fills the tire up better. the -2 is flatter.
#5771
The different sized cups are included with the Big Bores so you can use the same length springs on truck or buggy. The medium sized ones are always used on the B4 I believe.
#5772
Run the middle ones. They are mainly desgined for use with the truck, buggy you will always use the middle. Its not a tuning option. They only made front springs and rear springs, no more truck fronts / buggy fronts. By running a longer cup on the truck you can use the same length springs and still achieve proper ride height.
4Likes
I actually ran pretty good with them
