Like Tree5Likes
SC10 4x4 Thread
Old 05-24-2013 | 01:53 PM
  #34201
Wild Cherry's Avatar
Remember , lighter means you can run lower .....
This Lighter theory ?
Its edge ?
A heavier truck has to run at a higher ride height thus has less steering, traction & more roll ...
Wild Cherry is offline
Old 05-24-2013 | 02:03 PM
  #34202
Jordan Anderson's Avatar
I run mine the heavy way (ie. Exotek chassis, RC Shox center diff, etc.) because I run on a 1/8 bumpy/loose outdoor track...
Your ultralight theory is interesting though.
I'm considering trying 550 can to add weight.
Jordan Anderson is offline
Old 05-24-2013 | 02:42 PM
  #34203
Jordan
out doors would run higher then 19.5 mm
If you try ?
Also would consider switching to the blue rear spring ...
Old 05-24-2013 | 07:57 PM
  #34204
sugs's Avatar
Originally Posted by Cain
With it being ultralite, maybe a 540 Pro2 would work better. Less weight but not so much beastly initial torque that the 540 4 poles offer.
Totally agree with this direction. When Cameron Kellogg was successfully running this truck he ran a 2 pole 5.5 540 with a fan, and I think I remember him saying his truck was right around 94 to 95 oz. If you have it now down in the sub 5.5lb range, a nice torquey 2 pole sounds like it would be the ticket.
sugs is offline
Old 05-24-2013 | 08:28 PM
  #34205
Jstall7543's Avatar
Pro4 all the way for me. I tried the reedy 4.5 550 for 2 batteries and hated the way my truck drove especially while jumping it felt retarded, nose high always. Put the pro4 back in and I was back to driving better than ever. The 4.5 works excellent in my scte. Everyone is different, I know the 4.5 is a beast but I didnt like it in my FT SC10 4X4.
Jstall7543 is offline
Old 05-24-2013 | 08:41 PM
  #34206
Originally Posted by TomErickson
Pretty good. I had to replace a belt once. It was before the chassis brace when I cased a huge jump on an 8th scale track that flexed the chassis so much the belt popped off and got chewed up. The belt is still usable but has a kink in it so I saved it for a spare.
What failed on yours? Teeth, delaminated, snapped?
It stretched but it's not the only problem my front diff is toast jumping teeth
9turn is offline
Old 05-24-2013 | 08:58 PM
  #34207
Originally Posted by Kromulous
Cherry, or any of you guys do you run a 4 Pole motor with your LRP Flow?
I called LRP and they told me it should be fine, so i thought i may buy one of the HW 4 pole SCT motors and try one out.
Currently i got a 4.5 Novak ballistic, pretty much the only brushless i will run, and new Flow on the way.
Thanks, Krom.
I used a first gen Leo sphere and ran a fan with 4600 tekin
9turn is offline
Old 05-25-2013 | 07:24 AM
  #34208
Ranger411's Avatar
Had a weird occurrence last night with my SC10 4x4 and was needing input.
Setup right now is a RCshox diff with 6pins and 5k wt in front and back diffs. I was running it last Saturday during the day in 80+ degree and it ran flawlessly and was landing jumps clean. Go to last night and a cold front came threw to make it 40 degrees out. The truck couldn't even hit a step up without acting nuts, and it was uncontrollable. I went from the smoothest truck in the pack to embarrassed in a 4 day span at the same track.
My questions are: does the cold effect the truck that much, or is it just time for fresh dif oil and the weather was a coincidence?
Bought the truck here and the previous owner had just changed the oil. It has been through 30+ packs between practice and racing. There are traces of oil coming from the outdrive especially in the rear. I think I know the answer but was wondering if anybody experienced this and it will be fine when it warms back up.
Ranger411 is offline
Old 05-25-2013 | 08:07 AM
  #34209
BlueGlowBoy's Avatar
40 degrees is a BIG temp change, not only for diff oil, but shock oil too.
I know a few guys around here that have 2 full sets of shocks and diffs because you never know from one day to the next if you are going to be sweating or shivering on the drivers stand....
Can't say that's ALL your problem, but that is a BIG change in temp....
BlueGlowBoy is offline
Old 05-25-2013 | 11:03 AM
  #34210
Cain's Avatar
+1 . I would look more at the shock oil first based on what the poster is saying for sure.
Cain is offline
Old 05-25-2013 | 12:00 PM
  #34211
Ranger411's Avatar
It was 40 wt front, 35 wt back with 2 stage pistons. I guess it was a learning experience as it will be back in the 80s by the end of the week. Shocks feel real sluggish in the cold basement now that you mention it.
Old 05-25-2013 | 12:03 PM
  #34212
Cain's Avatar
I take it RC Shox 2 stages?
Outdoors I was down to under 30W Losi front and and rear on my SC10 4x4 at the time with the 2 stages. So i can imagine how that must have felt in the cold lol.
Cain is offline
Old 05-25-2013 | 02:02 PM
  #34213
Jstall7543's Avatar
Back in my XXT days when the track had no heat I would use a hair dryer to warm up the arms and shocks and tires sice the a-arms were so fragile in 25deg temps. My buddy and I were just talking about being out there at four seasons with ice crystals on the track in 1995 lol. We were die hards back then. But the hair dryers work. Used to use to warm up cold nitro engines also. This might work for you, try it out.
Old 05-25-2013 | 02:16 PM
  #34214
Ranger411's Avatar
Yup RC Shox. I bought fq06's 4x4 the note he had about running outdoors was to throw the 2 stages on and add 5 wt to the oil. Figured he knew the truck better than I do. I have some Losi 32.5 wt, you suggest I try that next time I swap oils or the problem continues?
Old 05-25-2013 | 02:21 PM
  #34215
Ranger411's Avatar
Its going to warm up in the next few days again anyway so I have another question.
Which would be better for a small to med size outdoor track, the Tacon 4 pole 4800kv I have been using or a Tekin Redline SC4X 5.5T that I just picked up cheap and have yet to use?
