Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-02-2013 | 08:33 AM
  #4711
mingoglia's Avatar
Originally Posted by brian94066
Finished my car, did experienced a slight problem though
That's funny, not sure if anyone else picked it up. Several months ago I purchased some AE tierods from the LHS and had exactly the same machining problem.... or lack of machining you could say. I sent AE an email and they sent me out a replacement set quickly.
mingoglia is offline
Old 05-02-2013 | 08:41 AM
  #4712
Wild Cherry's Avatar
Originally Posted by turbo2cam
I asked for your explanation the very first time I quoted your statement...I asked again 3 other times as well. So for the 5th time, how exactly does the slipper effect OFF power STEERING.
I understand your extremely generalized statement of "racers with handling issues have their slipper locked" and I agree that a locked slipper creates issues....but we are talking about 1 very specific situation during a turn. Off power traction while turning. Off power means NO THROTTLE. the slipper only functions when the motor is accelerating, or decelerating, UNDER POWER. (the motor is the driving force that makes the slipper function in the first place...hence being connected to the motor via pinion/spur) when the motor is in a neutral state (freewheeling) and the car is rolling (off power turning) then the motor is not inducing any resistance to make the slipper slip.
So again, explain to me how the slipper effects OFF-power turning?
Your claiming & posted there no way the slipper affects off power .
Incorrect
Its slips both ways, not just forward.
Going into the turn can lock the slipper and the car can become darty and steer more into the turns.
Loosen slipper and the car will be much smoother entering the turns.
Landing off jumps are also effected.
A tight slipper can make the car slide out on hard landings,not mention the extra wear & tear on the drivetrain.
Loosen the slipper and landings will become smoother ,more planted.
Does this answer your question?
I can show you even more how the slipper affects off power if interested.
Wild Cherry is offline
Old 05-02-2013 | 08:43 AM
  #4713
B00t13g's Avatar
Originally Posted by Autocratic
You going to run another ORCA or the Flow?
R10 pro, bls451, reedy 4100, reedy mach 2 7.5
B00t13g is offline
Old 05-02-2013 | 08:58 AM
  #4714
SEF's Avatar
SEF
Your claiming & posted there no way the skipper affects off power .
Incorrect
The OP mentioned pushing from mid to exit steering. The hard braking is done just before turn in, and maybe during turn in and mid turn you might try to use a little trail brake. There should definitely be no braking from mid to exit corner unless you totally messed up the turn.
In any case, drag brake or trail braking should never be hard enough to make the slipper slip. And if you are braking so hard going into a turn that causes the slipper to slip then you have way too much brake, your slowing down too much going into the turn, or you may be loosing braking traction, all of which are bad and will likely cause you to spin out when driving a 2wd buggy, and in no way should the slipper be the first thing you think about adjusting.
Just stop it if you think the "winning" method of getting better off power steering from mid to exit corner is by possibly adjusting your slipper.
SEF is offline
Old 05-02-2013 | 09:06 AM
  #4715
SEF
No brake needed to make the slipper give.
common knowledge
Tight slipper makes the car darty entering turns & traction middle to exit loose.
Old 05-02-2013 | 09:07 AM
  #4716
Incorrect
Suprisingly your not entirely wrong. I only noticed a difference when the slipper was near locked. When it was set tight or loose it felt the same. I couldnt tell if it was effecting turn in or turn out or maybe both. It felt weird and would spin out much easier.
chevmaro is online now
Old 05-02-2013 | 09:15 AM
  #4717
Wildcat1971's Avatar
Tech Prophet
WC is wrong wrong wrong wrong wrong. No one runs the slipper loose enough to slip on corner entry. Even on a super high bite with a 2 turn motor going full speed, I doubt the slipper would slip on full brake. In racing conditions you will never slip a slipper slowing for a corner. There is just not enough force being put on it. For one when you slow for a corner, weight is being taken off the rear wheels which even further reduces the forces on the slipper. This is truly the most brain dead thing Cherry has ever said. If this were a 4x4 and were were talking about a center diff, then this would be a conversation. But he is simply off his meds.
Wildcat1971 is offline
Old 05-02-2013 | 09:18 AM
  #4718
Autocratic's Avatar
When has Cherry ever been on his "meds" and made any sense at all?
Autocratic is offline
Old 05-02-2013 | 09:30 AM
  #4719
Cain's Avatar
I think we need BK to give us a definitive answer.
When you get the SC10 4x4 guys that vid you promised WC about the +8mm mod and how it works from BK, make sure and ask about the whole slipper thing too.
Cain is offline
Old 05-02-2013 | 09:37 AM
  #4720
Chev
The off power effects the slipper has is most noticeable on higher traction conditions.
When grip comes up so will steering, tight slipper can make the car darty and difficult to drive.
lCan just tighten my slipper a extra turn and my lap total can turn up a lap short.
Have learned how important the slipper effects a correctly set up ride, can become a game changer sometimes.
talkN bout way out there
just a tip to adjust a slipper and it becomes the main topic.
Oman !
Who would of knew...lol
Old 05-02-2013 | 09:38 AM
  #4721
Great packs, used them in a friend's 17.5 B4.2 and I was able to clear the indoor triple at my track every lap with no effort, 4300mah isn't bad either
Maybe I shouldn't have let you drive my car last Sat. Fast guys getting faster... Looks good Brian.
NovaCX12 is offline
Old 05-02-2013 | 10:19 AM
  #4722
Grandturk's Avatar
Anyone have a good wrench solution for the front shock nuts? Can't really go my regular nut driver in there to take the nuts off. Someting small to fit in their and still be able to turn the nut would be great.
Grandturk is offline
Old 05-02-2013 | 10:23 AM
  #4723
Tech Prophet
the kit wrench. its plastic but work well
its the one in the bottom right of this pic.
http://www.ebay.com/itm/Team-Associa...item20cf9ef1d4
Old 05-02-2013 | 10:25 AM
  #4724
Grandturk's Avatar
How pedestrian. I was hoping for something in aluminum or titanium that costs $30-$50.
Thanks. I never open those "tool bags."
Old 05-02-2013 | 10:26 AM
  #4725
t0p_sh0tta's Avatar
This. The one with the worthless turnbuckle wrench on the other side.
t0p_sh0tta is offline
