Team Associated B4.2 Thread >
Like Tree4Likes
Old 04-26-2013 | 11:51 AM
  #4561
Jake S's Avatar
Originally Posted by nicholasxuu
isn't wolf pack similar to shorty in weight?
no. ~260g for wolfpack, ~200g for shorties.
Jake S is offline
Old 04-26-2013 | 11:55 AM
  #4562
savageboy69's Avatar
Originally Posted by Odin544
I don't see the point in the JC low profile ball cups. There isnt a clearance issue between the wheel and ball cup anyways. And the JC low profile cups are thicker and rub on the springs even worse than what the original stuff does. They were on my B4.2 when I bought it. They are now off.
Because they were installed wrong, mine don't rub
savageboy69 is offline
Old 04-26-2013 | 12:03 PM
  #4563
probowler's Avatar
Originally Posted by the incubus
OK guys, just getting back into racing after a VERY long layoff and I have a T4.1 FT that I run the Ball diff. I traded my 22 for a 4.2 because the 22 just wasn't the same as AE for me, and it came with the Gear diff in it but I have all the parts to build the Ball Diff.
Question to you all is… Ball or Gear Diff?
Thanks.
ball diff for sure! Gear diff is usually used when there's an insane amount of traction like running on carpet or something.
probowler is offline
Old 04-26-2013 | 12:28 PM
  #4564
probowler's Avatar
here's a couple pics of the inline esc
Old 04-26-2013 | 01:27 PM
  #4565
the incubus's Avatar
Out of curiosity, why not run your motor wire (sensor and all) between your Wing Mounts and through the center opening in the shock tower? This way your wires are not so contorted.
the incubus is offline
Old 04-26-2013 | 01:30 PM
  #4566
Excellent. Thanks, it's what I thought as well. My T4 is dialed in for every type of track condition using the ball diff so I was leaning towards it. Now if my local shops would just get the outdrive bearings for the Tranny case, then I could have 2 complete Tranny's to swap as needed. This means I will be tearing down the Gear diff to use that case for the ball diff.
Old 04-26-2013 | 02:04 PM
  #4567
Question on Electronics (I know there's a section for that but it has very little foot traffic so I figured I'd ask here)
My Reventon R ESC's leads are a hair too short and I'd like to solder on new wire, but was looking for a specific color that by luck I found, only it's 14 gauge. The stock wiring on the ESC is 14 as well but I was wondering if there's an advantage to going with 12 over 14. If not I can order the wire right now and solder everything up once it arrives. I think it's will make my ride look so much sharper and totally unique.
Old 04-26-2013 | 02:06 PM
  #4568
Wildcat1971's Avatar
I doubt you will notice between 12 and 14 kn 2wd buggy
Wildcat1971 is offline
Old 04-26-2013 | 02:11 PM
  #4569
Thanks for the prompt reply Wildcat. Associated guys are still the best!
Old 04-26-2013 | 02:16 PM
  #4570
Lance Tanner's Avatar
I thought we'd lost you to the Kyosho thread When are you going to share your thoughts on that sled? Or have I missed that post?
Lance Tanner is offline
Old 04-26-2013 | 02:25 PM
  #4571
I have not driven it yet lol
Old 04-26-2013 | 03:19 PM
  #4572
Make sure u buy a alum steering rack or a lot of plastic spares, u will need em
Old 04-26-2013 | 04:15 PM
  #4573
my buggy came with an exotek alum rack I just might need some alum suspension holders.
Old 04-26-2013 | 04:39 PM
  #4574
thecman26's Avatar
R/C Tech Elite Member
*Or*
There is a TINY Protek 100C shortie that is 3000mah and 150g!
thecman26 is offline
Old 04-26-2013 | 07:10 PM
  #4575
Jake S's Avatar
god wish i had an extra +8 chassis, i still wanna try saddles mounted across, esc back of battery tray, and rx in the front of the battery tray.
using b44.2 mounts
Jake S is offline
