Team Associated B4.2 Thread
#3811
Wow! Two lucky guys are gonna win some awesome stuff from Yaiba Racing! My younger brother Cush (and Team Yaiba Racing driver) just ran his full Yaiba Spec B4.2 yesterday for the first time. Put it 3rd on the grid in a tough field where 1st-5th were seperated by five seconds, and only a second from 1st to 3rd. After some hard racing through the whole 6 minutes he wound up 4th- pretty solid for his first day driving the car! Only a matter of time before he puts the Yaiba Spec in the winner's circle.
#3812
I have never been on a mix of astro, dirt and grass, lol. But I am not sure what you mean you rear is bouncing. The whole thing hops? That would mean you need lighter oil. The motor looks like a yoyo going up and down while the wheels stay planted? Then maybe heavier oils. I would probably get the taper pistons for that track. That dirt looks like dirt dirt and not clay. You might need to soften the front a little.
)Especially on the carpet, it's a bit bumpy and when I steer on it, the car leans in. I could change that with a heavier spring.
What tapered pistons should I buy?
All of them and just test em or a specific set?
It's dirt mixed with some kind of sand.
#3814
I'll try them out when they are in stock here.
Just came back from the track and tested 1.7 with 32.5 front and 1.7piston 27.5 rear. seems like it soaked up the little bumps a bit better.
#3817
I'm running tapered 1.6 currently, the car is too soft/twitchy everywhere. If I increase oil wt to make it better, it becomes numb. I preferred the regular (non-tapered) 1.6. At $15 a pop for the tapered pistons, I'll stick to the regular non-tapered ones.
#3819
#3820
Try the Avid machined flat pistons in 1.6mm. fit tighter to the shock body and feel amazing. I have them mounted up for this weekend indoor racing. 32.5 front and 30 rear.
#3821
I really didnt like the 1.7's. The 1.6s were better on pack, but just not right in the corners. I personally feel like the corners are better with the 1.4x3's and I only slap on a tabletop ski jump I am full speed flat landing. I might work on down siding that jump in the future. I was just trying a few lines this weekend, but didnt really work on that one much as long jumping seemed fine. My buggy was getting about 5-6 feet in the air traveling about 15 feet and flat landing. It didnt bobble bounce or lose a beat. But it might be unnecessary punishment of my buggy.
#3823
#3824
#3825
4Likes
