Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-02-2013 | 10:28 AM
  #4726
Wildcat1971's Avatar
Originally Posted by Grandturk
How pedestrian. I was hoping for something in aluminum or titanium that costs $30-$50.
Thanks. I never open those "tool bags."
that and the shock tools are ok. I dont use much of the rest.
Wildcat1971 is offline
  #4727
Grandturk's Avatar
Originally Posted by t0p_sh0tta
This. The one with the worthless turnbuckle wrench on the other side.
At least I have a decent turnbuckle wrench.
Grandturk is offline
Old 05-02-2013 | 10:32 AM
  #4728
Grandturk's Avatar
Wow - I can't beleive they still have that shock o ring plunger thing. I remember that from my RC10T! I just built all the SC10.2 shocks by hand - just hand Tightening all the caps. Worked fine. Coming apart might be a different story.
Old 05-02-2013 | 10:36 AM
  #4729
I hand tighten mine to. But sometimes the cap is stubborn and I use the tool that goes around the hex to give me a better grip. lol, I broke my shock tightning tool last night for my rb6. And you cant hand tighten it. So I get to buy a fancy non pedestrian tool to replace it....yippy....not. At least the b4 tools are useable
Old 05-02-2013 | 10:44 AM
  #4730
the incubus's Avatar
Be careful. I did it by hand on my son's RB5 and as I was getting it dialed in for him, something changed dramatically in the rear and when I brought it in I noticed the right rear cap had unscrewed and dumped all the fluid all over the place. Thankfully it happened just a few corners before pit lane so it didn't take any big jumps but it was full of clay. Tore it apart and washed it thoroughly with the hose to ensure no debris was on anything and then rebuilt it using the tools. haven't had an issue since.
Lesson learned.
the incubus is offline
Old 05-02-2013 | 10:47 AM
  #4731
lol, I have an rb6 and I hand tighten then and it leaked. The b4, you can hand tighten and be fine. Different shocks and all.
Old 05-02-2013 | 11:55 AM
  #4732
Tradin Paint's Avatar
If your slipper is too tight it won't allow you to hand tighten the shocks properly. Always check your slipper before messing with the shocks
Tradin Paint is offline
Old 05-02-2013 | 11:58 AM
  #4733
One of my V2 shocks is sucking air. I can tell by that odd squeaking sound it makes. How do I fix it?
shagnat is offline
Old 05-02-2013 | 12:02 PM
  #4734
rebleed. If you think the seals are bad replace the orings and the shock cap seals. I have BB shocks. they always pull air, so I just rebleed them weekly and change the oil when contaminated
Old 05-02-2013 | 12:05 PM
  #4735
Thanks, Wildcat. Sooooooo...... BBs always suck air....... isn't that a shame! For $100 you'd think they could make a seal that would actuall "seal".
shagnat is offline
Old 05-02-2013 | 12:08 PM
  #4736
my kyosho BB shocks are also sucking air...... and they leak... so yeah.
Old 05-02-2013 | 12:43 PM
  #4737
elex300's Avatar
My BB's on all my kits have been great since using 3 of the limiters in place of the included center bushing. I would like to try the Factory One bushing too.
elex300 is offline
Old 05-02-2013 | 12:49 PM
  #4738
cherry-poop's Avatar
Default seal
try the TRL22 shock seal kit, specifically the small brass washer in place of the pink assoc seal on the bleed screw. i was told of this at the track and seems to work fine.
good luck
cherry-poop is offline
Old 05-02-2013 | 01:18 PM
  #4739
Get the factory one bushings. Problem solved!
v1/v2:
http://stores.factoryone-rc.com/-str...tra/Detail.bok
bigbore:
http://stores.factoryone-rc.com/-str...ore/Detail.bok
SAGISI is offline
Old 05-02-2013 | 01:56 PM
  #4740
bilster44's Avatar
good luck
He said one of his "V2" shocks...not big bore.
bilster44 is offline
