Team Associated B4.2 Thread >
Like Tree4Likes
Old 03-22-2013 | 12:23 PM
  #3211
Originally Posted by Wildcat1971
mah, I goto this track like once every 2 months. I will skip the tire sauce, lol. Just clean with simple green and call it a day.
@chev Yeah, it changes heat to heat for us. Soon we will goto night racing, so at least the mains should be consistent. But watering a track has so many variables, lol. Almost warm enough for night racing, time to paint up a bright body. I am think white (meh 2-3 of those) or flo pink. The track has bad lighting, so I need the paint to pop.
Just clean them and then about 5 min before you hit the track, hit em with motorspray. Try it in practice once with, once without.
Bob Barry is offline
Old 03-22-2013 | 12:25 PM
  #3212
elex300's Avatar
Originally Posted by Bob Barry
I use motor spray if I need to do a last minute tire swap and the tires I'm switching too aren't already gripped. It's not as good as gripping, but it's better than not gripping 99% of the time.
Thats why I use it. most of the time im running around helping guys out so I never get alot of time to prep my tires.. Doesnt seem to wear tires bad either.
elex300 is offline
  #3213
Wildcat1971's Avatar
How much longer till outdoor racing bob?
Wildcat1971 is offline
Old 03-22-2013 | 01:01 PM
  #3214
technically April 6th....but I mean they are calling for snow here this weekend so it may be just a tad bit longer haha
Old 03-22-2013 | 01:14 PM
  #3215
Originally Posted by Jake S
wow finally did the set screw mod to the rear hubs, my gosh did it tighten the rear up.
3 things that made the whole car ALOT tighter from stock b4.2...
rpm ballcups
ft 2 hole caster blocks
set screws in hubs
Jake, do you race anymore?
cooper126 is offline
Old 03-22-2013 | 01:35 PM
  #3216
Jake S's Avatar
yeah havent had saturdays to come race where you do.
Jake S is offline
Old 03-22-2013 | 01:51 PM
  #3217
the 2 hole casters help that much to tighten it up?
Old 03-22-2013 | 02:14 PM
  #3218
Jake S's Avatar
they did for me, and i got 2 race days on them soo far and still tight. its because they are machined not molded, so the tolerances are alot tighter.
Jake S is offline
Old 03-22-2013 | 02:17 PM
  #3219
I used to use them on the original b4. But after I got my WC, I seemed to stock pipe the 3 holes. And they dont seem to break, lol. So i have like 3 pair. I do have some slop in the front casters. I might have a carbon 2 hole laying around, I will try to see if it tightens it up a little. If so, I might pick a set up. The buggy is like 6 months old now, so even though slop is not bad, there are limits, lol.
Old 03-22-2013 | 03:40 PM
  #3220
aeRayls's Avatar
The 2 hole blocks are not machined, they are molded. They are just molded of a different/stiffer material.
aeRayls is offline
Old 03-22-2013 | 03:47 PM
  #3221
Matt Trimmings's Avatar
Correct. The hole for the hinge pin is drilled in the 2 hole blocks vs molded into the 3 hole blocks.
Matt Trimmings is offline
Old 03-22-2013 | 03:58 PM
  #3222
Jake S's Avatar
^ what i meant to type, but i guess i missed the "for the hinge pin" part.
Jake S is offline
Old 03-22-2013 | 06:16 PM
  #3223
What does the shaved u brace do or help or make better? Also, does it need to be used with the c hub only? Thanks!
NovaCX12 is offline
Old 03-22-2013 | 07:27 PM
  #3224
Razathorn's Avatar
The c hub lowers the roll center. shaving the u-brace and mounting the ball stud lower raises it back up. The theory is that lowering the link in general makes for different roll center behavior, even with the roll center starting locations can be adjusted the same as A hubs and a normal brace.
In general, people shave their brace and go to a c hub at the same time, but using A or B hubs with a shaved brace is also a very valid tuning option, allowing for a significantly higher roll center. I run A hubs with shaved brace and 2 washers with green rear springs at my track -- this is what works at my track. White springs on a higher bite surface are typically paired with c hubs and a shaved brace followed up by ballstud tuning at the inside brace.
Run what works, don't be afraid to experiment.
Razathorn is offline
Old 03-22-2013 | 08:31 PM
  #3225
F18engineguy's Avatar
Bob, where are you racing outdoors?
F18engineguy is offline
