Team Associated B4.2 Thread
#2461
Its getting better, I just need to get it to where my old b4.1 was at and I'm pretty close. Another day or so at the track with some minor changes and testing should get me there.........
#2463
I changed my slipper to the new 4.2 slipper, I'm using the stock spring and I have to have the nut so backed off to set the proper tension that its only on half way.
I have the stock output shaft, a B4.1 slipper pad, the spur, the new slipper housing, a new slipper pad, metal plate, new slipper pad, then the final outer most slipper plate from the new slipper, the stock spring and then stock nut
all the pads are sitting flat especially the very first one that kinda hidden back there.
Any ideas?
Any ideas?
#2464
Any ideas?
Any ideas?
should show about 4 or 5 threads ( 3mm) above the lock nut
#2472
4Likes
