Team Associated B4.2 Thread >
Like Tree4Likes
Old 01-31-2013 | 05:57 PM
  #961
Picking mine up in the morning. Body all painted, tires glued. Should have it built for racing tomorrow night. Can't wait!!
DJG24 is offline
Old 01-31-2013 | 06:13 PM
  #962
Wildcat1971's Avatar
let us know how well the new tower work.
Wildcat1971 is offline
Old 01-31-2013 | 06:37 PM
  #963
Makarrov's Avatar
Huzzah! Just got a call from my LHS, my buggy will be ready for pick-up tomorrow!
Makarrov is offline
Old 01-31-2013 | 06:47 PM
  #964
meh, blew up another set of bearing in the rear hubs. The avids did last longer though. I am seriously thinking about going to the plastic hubs. I just dont want my shocks to rub my links. Anyone running the plastic b44 hubs with lunsfords? How bad is the rubbing?
Old 01-31-2013 | 06:58 PM
  #965
Razathorn's Avatar
I run plastic b44 hubs on my b4. I run a thick plastic washer, I think .090, and no spacer up top with a shaved tower. Doesn't rub much at all. I see some, but it's due to b44 rear arm flexing.
Razathorn is offline
Old 01-31-2013 | 07:51 PM
  #966
Tradin Paint's Avatar
Something is wrong. I have not blown a rear bearing in 2 years
Tradin Paint is offline
Old 01-31-2013 | 08:02 PM
  #967
Maybe. It is mostly the left hub
Old 01-31-2013 | 08:12 PM
  #968
If you run 0 degree then I would say to just try the plastic and see what happens
Old 01-31-2013 | 08:16 PM
  #969
Yeah. I plan to
Old 01-31-2013 | 09:17 PM
  #970
GizmoTLR's Avatar
Josh at DBRC i know ur on here....u get them in yet?
GizmoTLR is offline
Old 01-31-2013 | 09:52 PM
  #971
Cridd's Avatar
Originally Posted by hobbyten
They had a graphite chassis for a while after the alum. then went to composite.
TQ 10 right?
Cridd is offline
Old 01-31-2013 | 10:01 PM
  #972
Cridd's Avatar
Should have my B4.2's on Tuesday. My kid said Viper and I wanted to get him a Reedy, said screw it and got him what his heart desired. Told him we can drag down our driveway and see who wins! I'll post video next week if we actually get around to it.
Cridd is offline
Old 01-31-2013 | 10:02 PM
  #973
Just1More's Avatar
still have a crush tube between the bearings? is it the same length as the right one? The transmission uses one also.. make sure you didn't mix em up if they're different lengths. Could also use a shim or two to make the crush tube seem longer to take pressure off the bearings. They're side loading and blowing out prematurely..I've never had one go bad
Just1More is offline
Old 02-01-2013 | 12:55 AM
  #974
mdowney's Avatar
Does anyone have the part numbers for the new big bore shock towers or any idea on when they will be released?
mdowney is offline
Old 02-01-2013 | 01:04 AM
  #975
Wild Cherry's Avatar
Tech Legend
crush tubes wear out
busted bearings can be caused by a worn out tube
downey ,
believe towers will be same part # and treated just as a running change
Wild Cherry is offline
