Team Associated B4.2 Thread
#3242
I just finally updated to the big bore shocks on my Worlds B4.1 but confused a bit about shock standoffs/spacing. I did search first but too many posts to sift. Anyway I am trying to make sure I have the shocks right I got the updated towers, and the Avid short standoff for rear ,also the Avid standard standoff for front is the correct setup with new towers or should both standoffs be short? I also am wondering if I need to space the lower shock mount out from rear arm still with updated towers? OK one last question whats a good locknut to use on upper shock mount that won't gash the caps or come off? I lied how tight do you run the bleeder screw in seems to make oring pop out really easy? Thanks for any info/help!
#3243
#3244
[QUOTE=mashimarowu;11963941]Just space it so you don't have any binding when the stock is compressing/decompressing. Make sure to not have the shock scrape against your turnbuckles. As for the bleeder screw, tighten it till you can see the oring start coming out, no need to fully tighten it or else your oring will pop out. Just snug it up.[/QUOTE. Ok Thanks! I really appreciate the help and any other advice on getting setup correctly.
#3245
Well got some good practice on the b4 today. Also, shorties can run for a LONG time. Lol. I put one pack in ran for 30 minutes, slapped another pack in and ran for 30 minutes and the motor was 110. I was actually suprised when my car stopped... lol. I was like, huh..oh lvc. I have never ran by b4 rill lvc before. Anyway, I let a few guys drive my buggy, mostly they hated my radio, but like the way the buggy handles. The said the wheel on my radio was too small and i replied that size does not mater.....
#3246
What radio?
#3248
Hi all,
Just looking for some info on my B4, need more speed down the straights, looks a lot slower than the newer TLR 22, BL Novak 17.5 72/36, large out door track, any info would be helpful.
#3249
Other than faster motors or stronger battery, over my pay grade.
#3250
I dont see why you would be a lot slower down the straight. For one the b4 is lighter than the tlr. Maybe they are cheating. lol. How much timing are you running?
#3251
Other than that, the batteries, gearing, and motors make a big difference in stock.
#3252
Is timing adjustable on the Novak motor? More timing on the can will give you more top end. I haven't run 17.5 in so long, I don't remember what gearing works, but most here are running the 69 tooth Kimborough spur.
#3254
4Likes
