Team Associated B4.2 Thread >
Like Tree4Likes
Old 04-30-2013 | 01:23 AM
  #4621
Odin544's Avatar
Originally Posted by savageboy69
I believe more caster gives u less entry steering but more mid to exit, some one will chime in and confirm or deny it lol
per Hudy Offroad setup book...
Less Caster
• Decreases straight-line stability
• Increases off-power steering at corner entry
• Increases suspension efficiency
More Caster
• Increases straight-line stability
• Decreases off-power steering at corner entry
• Makes the car more stable through bumpy track conditions
per http://users.telenet.be/elvo/
Caster
More caster aids stability, and handling in bumpy sections.
Less caster increases steering drastically. Steering feels much more direct, the car turns tighter and faster.
Odin544 is offline
Old 04-30-2013 | 06:50 AM
  #4622
Thanks guys. Very big help!!
shagnat is offline
Old 04-30-2013 | 08:57 AM
  #4623
Wild Cherry's Avatar
Originally Posted by shagnat
I'm going to buy some additional castor blocks for back ups.
Do I want the 25* or 30*?
Which does what better?
outdoor racing on clay w/13.5t motor
25 for outdoor ,loose conditions
30 for indoor & high traction
Wild Cherry is offline
Old 04-30-2013 | 09:14 AM
  #4624
Cain's Avatar
some more info from another site:
http://www.competitionx.com/rc-racin...tuning-caster/
Navigation Arrow Tuning with Caster
More Caster will make your car easier to drive. It will also make it more stable on the straights and through bumpy sections.
Less Caster will give the car more front bite into corners and make it react quicker to steering inputs. Less Caster will also make your car feel a little more twitchy.
Cain is offline
Old 04-30-2013 | 09:17 AM
  #4625
Autocratic's Avatar
Try to find the FT caster blocks. They'll have two ballstud holes instead of three. The two hole blocks have the hinge pin hole drilled and they fit tighter giving less slop.
Autocratic is offline
Old 04-30-2013 | 10:34 AM
  #4626
On power steering is good. Turn in is good. Traction is good. I just want a little more steering Mid/Corner exit off power. Every time I try to tune for this my rear end tries to spin out on exit. How can I accomplish this while keeping the rear end in check?
chevmaro is offline
Old 04-30-2013 | 10:40 AM
  #4627
Cain's Avatar
What's your setup?
What conditions and what tires?
Cain is offline
Old 04-30-2013 | 10:49 AM
  #4628
Keep in mind I just need a subtle change. The car is really good. I race on medium/high bite clay indoors. I like to run Gold Barcodes front and rear. Closed cell or open depending on the day. Just pushing a teeny bit on exit. Every time I make a change its just too far and I cant square up on exit. Thanks for the help.
Front
Shocks: 1/0
Link: 1A
Washers 1 blue 1mm washer 1 silver .030
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Black
Oil: 32.5 2x1.6
Camber: 1
Limiter: 3
Rear
Shocks: 1/0
Springs: Green
Oil: 30 2x1.6
Link: 1/B, A HUBS
Washers: 0
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: 1
Limiter: 2
Ride: 24
B44 rear arms, ballast weight. Shorty pack all the way forward. No other weight added. Run in stock buggy with 69 spur.
chevmaro is offline
Old 04-30-2013 | 11:01 AM
  #4629
aeRayls's Avatar
Front
Shocks: 1/0
Link: 1A
Ride: 24mm
Bump: 2mm
Caster: 30
Springs: Black
Oil: 32.5 2x1.6
Camber: 1
Limiter: 3
Rear
Shocks: 1/0
Springs: Green
Oil: 30 2x1.6
Link: 1/B, A HUBS
Washers: 0
Wheelbase: Middle
Toe: 3
Squat: 2
Camber: 1
Limiter: 2
Ride: 24
When you say square up... Do you mean that on exit your car wont rotate that little extra bit and when you grab throttle it has a push off the corner?
aeRayls is offline
Old 04-30-2013 | 11:06 AM
  #4630
aeRayls's Avatar
Actually I just noticed... You listed your rear shock mount as 1/0 is that right? You are inside on the tower and outside on the rear arm? If so that'd create some issues.
aeRayls is offline
Old 04-30-2013 | 11:23 AM
  #4631
turbo2cam's Avatar
you want more steering mid corner, OFF power, because it's pushing?? Sounds to me like you just need to enter the corner with a little less speed? If that's not the case, I personally would try moving the battery back a tad. Sounds like the front end is pushing because of weight transfer forward....if you slide battery back, it will help with the push, and help with forward traction once you get back on power...Im still a tuning n00b so that may or may not be good advice lol
turbo2cam is offline
Old 04-30-2013 | 11:27 AM
  #4632
Chev
Loosen the slipper, could be to tight..
Old 04-30-2013 | 11:39 AM
  #4633
Cain's Avatar
from what I recall when I ran barcode fronts versus scrubs fronts, the scrubs gave me more front bite, I even went with the barcode fronts as the scrub fronts gave me too much steering in comparison to barcode rears (they were great with switches though). Not sure if you open to trying a different front tire.
Have you tried less shim(s) under the front tower ball stud? In general if I felt the rear end was good, I played with the shims under the ball stud on the front tower to adjust how much bite I was seeing up there. It may be that little change could give you what you need but still keep the rear feeling "right" for lack of a better word.
Just some thoughts, could be way off base here but figure the change is quick if you haven't already tried it.
Cain is offline
Old 04-30-2013 | 11:54 AM
  #4634
Bigwerm's Avatar
Does anyone know the part numbers to do a losi spring convertion..???? Ive had noo luck finding these part numbers...
Bigwerm is offline
Old 04-30-2013 | 11:55 AM
  #4635
Wildcat1971's Avatar
Tech Prophet
check the first page of the b4.1 thread.
Wildcat1971 is offline
