Serpent 811E Buggy Thread
#3663
So all the kits are shipping with the wrong o-rings? All 6 diff bags had the big o-rings pictured on the last page in the 2 kits I just picked up from Serpent America yesterday
#3666
Hi guys just bolting on the 2.0 upgrade on my Be running on Astro and on a bumpy track aswell running purple rear, what holes are stock please and have you a rear end set up for me thanks, the car as always ran well so I never really changed much from PorkChop RIP. always ran 27.5 oil aswell and 10 hole pistons.
#3667
Great first time out with my buggy. ran a total of 2 packs through it before racing it.
Box stock setup, with the right tires got me 3rd place this weekend at the local club race, with quite a few fast guys in attendance.
Now i am going to start working on tuning it and see what i like to make it go a little bit faster
Someone please school me on tapered pistons, do you typically run them with the taper facing down and flat up to help give a bit faster rebound than compression?
I am also thinking of starting out with rear camber and roll center changes to pick up just a tad more side bite.
#3669
I assume LR means lower roll center, doesn't lowering the roll center take away side bite in general? making the car flatter through turns?
Not saying you are wrong, because sometimes i know the opposite of the expected result happens depending on other setup factors
If you are getting good results with it i will have to try it for sure.
Just a Tad more side bite and this thing will be spot on perfect.
Also, im running 6 hole right now with 300CST (stock 2.0 setup). Do the 8 hole tapered pistons keep the plush feel? or pack up @ lower shaft speeds like what typically happens when you go to more and smaller holes?
#3674
I had not seen that they were discontinued. I think pretty much any 16mm piston works, and it is a common size for many buggies. I am running the black pistons now also, and they felt good. I ran the RCShox dual stage pistons in my old 4X4SCT and might consider it for the 811 also. I also have a set of Fioroni's that came with a parts car I want to try too. Just trying to get the rest of the setup down first. I think any of the machined pistons are good though, CSI, Serpent (the white ones), Fioroni, etc.
5Likes
