Tekno RC EB48 Thread >
Like Tree2Likes
Old 04-22-2013 | 05:38 PM
  #5866
LAZNICK RC's Avatar
Originally Posted by kufman
I have been away from this thread for a while and was wondering if there has been a true fix for the servo saver problem yet? I saw a while ago that someone modified a Serpent spring and it worked well? Thanks.
hello
tekno is working on a solution to this ongoing issue they may testing as we speak send an email to tekno and find out were they are with it let us know what you hear
LAZNICK RC is offline
Old 04-22-2013 | 05:39 PM
  #5867
kufman's Avatar
Originally Posted by justpoet
Here's the 12 min race we were referring to earlier. My driving can still use some improvement (I really need to stop first lap crashing), but it went pretty well.
What went up in flames in that one car?
kufman is offline
Old 04-22-2013 | 05:45 PM
  #5868
Slotmachine's Avatar
O/K Tekno..............when are we going to see an E/Truggy based on the EB-48? I think I would have to have one when its available.
Slotmachine is offline
Old 04-22-2013 | 06:06 PM
  #5869
LAZNICK RC's Avatar
hi all
anyone know what production run number the eb48 is at is 3 or 4!
thanks looking at buying another one for my son
Old 04-22-2013 | 06:17 PM
  #5870
Cain's Avatar
+1 .
Cain is offline
Old 04-22-2013 | 06:27 PM
  #5871
Originally Posted by Cain
+1 .
+1
isaakh is offline
Old 04-22-2013 | 06:38 PM
  #5872
kufman's Avatar
After dong some further investigation, I can see why the stock servo saver doesn't work and a different spring isn't going to fix it. Here are the problems that I can see.
1. The spring has no way to slide on either the tension nut or the lower half of the bell crank. The spring is not providing torsional force. Its only job is to provide compression for the ramped sections of the saver. The spring needs to be able to slide on either the bell crank or the tension nut and it needs to be able to slide freely. Right now it can slide but only with a lot of force. If it does slide one way and then the saver tries to recenter, the spring may be trying to hold it in a non-centered position. I looked at my RC8 and there are washers in there to help the spring slide. Ideally this would be a pressure bearing with washer on either side.
2. The ramp sections in the bell crank are a different shape than all the other cars I own. The other cars use a non-linear shape in their servo savers where the EB-48 has flat angle ramps. The two pieces also don't fit together very well and there is some slop between the upper and lower sections. I know Losi struggled with the same problem and has changed the shape of their servo saver, although their major problem is that their servo saver is still upside down (servo saver action changes the toe-in/toe-out of the front end).
If Tekno fixes these two problems, the servo saver will work much better.
kufman is offline
Old 04-22-2013 | 06:55 PM
  #5873
Rockthecatbox21's Avatar
Unless you're running on super high traction tracks, i don't see why the servo saver is an issue. My servo saver is set with 2 mm of space inbetween coils and i never feel like it's hindering my steering.
Rockthecatbox21 is offline
Old 04-22-2013 | 06:59 PM
  #5874
Originally Posted by geekbox
Does anyone know of a place that sells a screw kit of the EB48 besides that stainless steel RCScrewz kit?
This guy has every screw you need. Hardened steel. Better than what comes in most kiyts: http://www.4chobbysupply.com/servlet/StoreFront
Tell him what car it is for and he can put a kit together and cost less than everyone else.
Rhymenocerous is offline
Old 04-22-2013 | 07:05 PM
  #5875
That would be my RX8, might be from the impact from shorting the jump a turn before it went up. I lost throttle when it nose dived and went up in smoke.
[IMG][/IMG]
ryno726 is offline
Old 04-22-2013 | 08:06 PM
  #5876
brian94066's Avatar
The same thing happened to me, landed the double kickup a bit hard and ESC went into total failure
Just got my replacement from Tekin, the heatsink is now black instead of red
brian94066 is offline
Old 04-22-2013 | 08:28 PM
  #5877
justpoet's Avatar
Originally Posted by streetsports
also theres one steering block screw on the eb48 that keeps backing itself out
Which one? I haven't had any back out and I've been running it since the first batch of kits shipped. I'd like to triple check though, to be sure.
justpoet is offline
Old 04-22-2013 | 08:41 PM
  #5878
add heat shrink on battery wires.
BTW, is tekin's wire 14AWG? it seems much thinner than the 12AWG wire I used for my battery.
nicholasxuu is offline
Old 04-22-2013 | 08:51 PM
  #5879
Originally Posted by doc danger
I ran this combo last year and had good success all season with temps. I never ran a fan on the ESC or motor. After a 10 min main in 95 degree heat, motor was 155 and esc 135. This may vary if you are running a high "C" rating on the battery. You need to run a 19T pinion with the current limiter at 85. Timing on the ESC at 10 (which is actually only 3 degrees of timing). Be sure you have a few holes in the body for ventilation on the right front corner.
Also a good idea to adjust the start and end RPM on the esc to 5000 - 30000.
I am running the 19T pinion now with the Speed Passion SA2 and getting even lower temps and efficiency so far. But it is still cool weather here and we'll see how it handles 95 degree summer days.
Thanks for the advice, but doesn't timing going to increase temperature on the motor?
I'm tried 18t and it way 170+F on both ESC and motor, after 8 mins main, on a relatively cool day. Used 17t and it's better, I doubt 19t will work...
and, what's the RPM for?
Old 04-22-2013 | 09:13 PM
  #5880
brian94066's Avatar
The wires look like standard 12ga but the insulation is pretty thin
