Tekno RC EB48 Thread >
Like Tree2Likes
Old 04-03-2013 | 10:11 AM
  #5521
Afun's Avatar
Originally Posted by ChrisAttebery
It should be 3/2. Which Blair setup are you looking at?
I may have messed up. I have 3 set up sheets laminated inside my trailer hanging on the pegboard. I may have looked at the wrong one. Maybe I should just try it at 5/0, and I do have he fluids at 5,5,3.
Afun is offline
Old 04-04-2013 | 05:50 AM
  #5522
Afun's Avatar
Last night I used a variation of Balirs set up. 5,5,3 diff, 35/30, 1.3x8 Kyosho pistons, light blue Kyosho springs all around, rear pushed back all the way 5mm shimmed front of hub. 2050kv geared 16/46, max amps race pack. All other parameters just like Blair's set-up. First qualifier I did not remove any of the braces. The rear was stiff and would swing around pretty good. I removed the rear brace for the main and the car changed. I mean it was hooked up. If I remove the rear light blue Kyosho springs and go to a orange or yellow, I think it will be perfect. Finished second in the main. I wish I would have tried HB Megabites instead of AKA impacts on our track. It was quick Wednesday night race, so I left it alone. I hope the NB48 will be similiar to this car.
Afun is offline
Old 04-04-2013 | 07:25 AM
  #5523
Anyone have a link to the Balirs setup that is being referenced?
*edit* think I found them. http://www.teknorc.com/eb48-setup-sheets/
RokleM is offline
Old 04-04-2013 | 08:58 AM
  #5524
bcjoldbq's Avatar
Default Kyosho springs
Why do some setups use Kyosho orange springs (i.e. Barry Baker setup on Tekno site)?
Are they softer than any offered by Tekno? More progressive?
Thanks.
bcjoldbq is offline
Old 04-04-2013 | 09:34 AM
  #5525
ChrisAttebery's Avatar
The Kyosho rear orange springs are rated at 3.4lbs where the stiffest Tekno rears are 2.93 lbs.
I asked Blair this question and he said that those are the springs/pistons that everyone uses for nitro buggies so they really understand them. He also said that they support the car better and make it easier to land when the car is out of shape (not bottoming out).
To me the Kyosho Light Blue/Orange springs feel firmer compared to the Tekno front yellow and rear orange.
I just put a set on my car. I can give you more feedback after this weekend's race.
Chris
Thanks.
ChrisAttebery is offline
Old 04-04-2013 | 10:05 AM
  #5526
Afun's Avatar
Thanks.
I felt the car would sag with the stock Tekno springs. With the stock Tekno pistons I would have no rebound. The Tekno Springs got worse with age. They weren't alway like that. I've been racing this car since launch. The Kyosho light blue springs all around may be a bit too stiff. I will soften up the rear with orange ones.
Afun is offline
Old 04-04-2013 | 10:39 AM
  #5527
bcjoldbq's Avatar
[QUOTE=ChrisAttebery;12008873]The Kyosho rear orange springs are rated at 3.4lbs where the stiffest Tekno rears are 2.93 lbs.
Are Tekno springs rated in lb-in anywhere instead of wire dia. x # of turns?
bcjoldbq is offline
Old 04-04-2013 | 10:45 AM
  #5528
IIGQ4U's Avatar
As illustrated on Tekno RC's Website:
IIGQ4U is offline
Old 04-04-2013 | 10:48 AM
  #5529
What he said ^
Old 04-04-2013 | 10:56 AM
  #5530
bcjoldbq's Avatar
oh geeez.... hate it when that happens....
bcjoldbq is offline
Old 04-04-2013 | 10:57 AM
  #5531
IIGQ4U's Avatar
Yeah, so do we.
IIGQ4U is offline
Old 04-04-2013 | 10:59 AM
  #5532
Cain's Avatar
don't feel bad, last time I looked for it it wasn't in a place I would have thought to look myself lol.
For heavier rate springs, I also use these charts that I found online or worked out in excel:
Code:
Hot Bodies D8 spring rates
Part #	Length	Force	Color	Lbs
67446	60	74	Gray	4.14
67447	60	81	White	4.54
67448	60	89	Blue	4.98
67449	60	98	Orange	5.49
67450	68	59	Green	3.30
67451	68	68	Yellow	3.81
67452	68	81	Red	4.54
67453	76	52	Gray	2.91
67454	76	59	white	3.30
67455	76	63	Blue	3.53
67456	76	74	Orange	4.14
	Associated RC8.2 Rates
	Front		Black	3.30
	Front		Silver	3.90
	Front		Green	4.00
	Front		Silver 8.2	4.30
	Front		Blue	4.65
	Front		Bronze	4.70
	Rear		Black	2.70
	Rear		Green	3.25
	Rear		Silver	3.30
	Rear		Silver 8.2	3.55
	Rear		Blue	3.75
	Rear		Bronze	4.00
	Xray 1/8 Spring Rates
Front	White	0.65	3.7115
Front	Grey	0.7	3.997
Front	Grey-Blue	0.8	4.568
Front	Blue	0.86	4.9106
Front	Violet	0.92	5.2532
Front	Purple	0.98	5.5958
Rear	White	0.47	2.6837
Rear	Grey	0.5	2.855
Rear	Grey-Blue	0.57	3.2547
Rear	Blue	0.61	3.4831
Rear	Violet	0.65	3.7115
Rear	Purple	0.7	3.997
Cain is offline
Old 04-04-2013 | 11:49 AM
  #5533
I was using the K car blue fronts and orange rears with the stock pistons. It was ok, but not great. I switched to the K car 8X1.3 pistons and it works really, really well.
MX304 is offline
Old 04-04-2013 | 11:58 AM
  #5534
Cain's Avatar
mine has the 1.3mm x 8 hole pistons, and the Xray blue-grey fronts and blue rears and from the bit I got to drive it it was very good.
Cain is offline
Old 04-04-2013 | 12:34 PM
  #5535
ravage's Avatar
Im Selling my dxr8e and going to get either the eb48 or the d8 hara with the tekno chassis. which is better in terms of handling. Any cons and pros on these? And what are the main differences besides chassis lay out?
ravage is offline
