Tekno RC EB48 Thread >
Like Tree2Likes
Old 03-23-2013 | 07:32 AM
  #5371
RC_Woody's Avatar
Originally Posted by streetsports
Adds pack...when the shock is pushed into the body the fluid wants to go to the center (away from the piston holes) and when its pulling out the fluid wants to push to the outside( toward the piston holes)....it does roughly the same job as the double action pistons but in a way smarter way. At least that's how I understand it....slows the compression without slowing the decompression.
Originally Posted by mdwalsh
the reasons you listed are correct. conical shaped pistons affect the speeds at which pistons go up and down direction-ally... i.e. faster one way or the other depending on the direction of the piston.
some tracks this can be made to work. bumpy tracks you want fast compression and slower rebound so the car doesnt get upset in the ruts, and some tracks with bit air you want slower compression so the car doesnt chassis slap.
where it gets complex is with pack. because it changes each direction the pack changes as well. pack really helps the car get out of a corner and land properly. with conical pistons the car always feels floaty and disconnected to me unless you run thick oils (fine for a smooth track) but it compromises the car in any kind of bump.
if youre really wanting to tune the shocks and not get frustrated in the process just grab those normal kyosho 1.3 pistons i listed. its a simple answer and they are much easier to tune, more consistent.
Matt
Thanks guys Jessie and Matt, that was more what I was looking for.
Matt, the pistons you are referring to are they
part# KYOIFW405-138 Kyosho SP Big Shock Piston (1.3 x 8 hole)
or
part# KYOIF347-138 Kyosho Big Bore Shock Piston (1.3 x 8 hole)
Not sure what the difference other than the SP are black.
RC_Woody is offline
Old 03-23-2013 | 07:45 AM
  #5372
doc danger's Avatar
Default sand the diff case
Something that i have learned when building diffs, is to lightly sand the flange of the plastic diff case prior to assembly. Prevents leaking where the flange meets the gasket.
Just get some fine to medium grit sand-paper on a flat surface. Take the plastic diff case (empty with no parts or o-rings inside) and turn it flange side down. Lightly moving it across the sand paper back and forth while turning it slightly. Only remove enough material so that it removes the "shine" from the mold and is now flat. Clean the diff case and be sure there is no debris in the threaded holes.
This should help with leaks at the flange.
If leaking at the o-rings, use a little more grease on assembly and give the o-rings time to seat or swell after break-in. This shouldn't take more than a few runs.
doc danger is offline
Old 03-23-2013 | 05:04 PM
  #5373
Genebaby's Avatar
Hi Doc, I have heard of that with other brands, it didn't seem to be an issue with the Tekno stuff, but is probably good practice with all.
I may very well have overfilled. Once again, I wasn't entirely sure so I didn't want to be under filled.
So it may stop? This is what the area looks like after running the diffs in.
Genebaby is offline
Old 03-23-2013 | 05:23 PM
  #5374
scoopdaloop's Avatar
My 410 did that too the first time I ran it after building it.. took the diff out and I was able to easily turn all 4 screws in half an hour.. I swear I tightened them plenty building but I guess not.
scoopdaloop is offline
Old 03-23-2013 | 07:26 PM
  #5375
since the screw bosses go all the way through the diff cup i found that diff oil got in mine and was thrown out when i did the diff break-in....i took the center diff out and could see that it wasn't coming from the gasket area...
beaven is offline
Old 03-23-2013 | 08:02 PM
  #5376
Genebaby's Avatar
Ah, that could be it too, I'll clean it up and gun it again, see what happens......all good, quite a learning process.
I must say it's very cool that there is a perfect spot for a Mylaps transponder, and even the screws are provided, and a little hole in the side for the cable!!! Very good stuff!
I only got the transponder recently and was surprised it didn't come with mounting screws, just the frame.
Genebaby is offline
Old 03-23-2013 | 08:09 PM
  #5377
Genebaby's Avatar
What do you guys think of these connectors instead of soldering in bullets in between the ESC and motor?
http://www.jaycar.com.au/productView.asp?ID=PT4800
http://www.jaycar.com.au/productView.asp?ID=PT4802
Not sure if 5mm ones are available anywhere, these guys don't seem to have them. Otherwise seem good if crimping offers less resistance compared to soldering.
Genebaby is offline
Old 03-23-2013 | 08:20 PM
  #5378
brian94066's Avatar
Don't look like they're rated for high voltage
brian94066 is offline
Old 03-23-2013 | 08:25 PM
  #5379
Canadianrage's Avatar
Was hoping to have a kit put together for the TLR Shootout this weekend, but can't find an EB48 anywhere Backordered and nothing on Ebay or the For Sale section...
I've got my pile of electronics ready to go, but no car...
Canadianrage is offline
Old 03-23-2013 | 08:40 PM
  #5380
Genebaby's Avatar
Good call, I forgot about voltage ratings, don't want to melt anything! I think I'll just do the bullets.
Genebaby is offline
Old 03-23-2013 | 08:42 PM
  #5381
kman16jr's Avatar
http://gshobby.com/node/225244
kman16jr is offline
Old 03-23-2013 | 08:53 PM
  #5382
Thanks!
Old 03-24-2013 | 09:33 AM
  #5383
Alright, gearing suggestions for a T8 2050, track will be 120' x 70'...
Old 03-24-2013 | 10:27 AM
  #5384
kufman's Avatar
They are rated for plenty of voltage (what we do is low voltage), but they are tin plated and will not handle the current. They are very similar to the bullets that come on Tamiya brushed motors.
kufman is offline
  #5385
kufman's Avatar
oooops, double post.
kufman is offline
